ADM Performance Stage 2 tune!!!!!
Nope, they use an 8 bit value to represent the manifold pressure which can only go to 255. Without going thru the math I've seen others use at HP Tuners that equals roughly 22.5lbs of boost.
This is suppose to change with the pending release of the GM stage kit but we shall see.
An 8 bit D - A is generally a chip that is soldered to a board, to get the resolution any better one would have to change the chip. If GM is changing the highest value that PCM to something higher. Are they intending to change the PCM and the sensor, or, just changing the sensor and rescaling the output value?
Interesting
D.
http://delphi.com/shared/pdf/ppd/sensors/et_mapmat.pdf
Leaks indicate it's a register shift. Maybe somethng like these get support...
I can believe a shift or a shift with math but they would still have to rescale the table/s and again they have access to tables we aren't seeing with HP Tuner, yet.
Load could be calculated from the map sensor, 100% load could be 0 PSI or 14.7 absolute and 200% could be the highest value the PCM can read from the A -D but it would still need to go into some sort of table I would think.
Don't know enough about this PCM, Yet.
D.
Agreed on the scaling. 3.5 bar... wheeeee. I'm not planning 50psi, but 30 sounds good
Re the scaling, it's pretty clear they will have had to do something big, and again, leaks from inside are saying this is an OS rewrite.
Hopefully HPT will be able to open the new OS as well and allow things to proceed even farther.
Not for me. Only for those that choose to buy the Chevy tune. Which while having some interesting possibilities will initially have less HP and torque then the current OS tuned via the HPT system.
D.
XXL, have you installed your snow injection system yet?
