Another Loss of Boost Question...
Old Mar 28, 2010 | 10:12 PM
  #31
pitbull76's Avatar
Originally Posted by peevlos
back from my 4 hour sit-a-thon at the dealer.
the 1st tech knew nothing about the Turbo Upgrade let alone GM makes it. Said its the first SS he has driven, that my car was "plenty peppy" and pushing 20psi which is the most it should push!
he then showed me a bulletin stating such... I showed him, said bulletin was for stock. then he told me by adding the 3" exhaust I lost back pressure causing loss of boost (he couldn't explain how though) could be cause he is full o'poop
in comes tech #2
show them on GMpartshouse.com that the Upgrade will allow boost above 22psi and up to 29psi they said "oh........yea" and kept reading.
ended up telling/showing me the wastegate solenoid is failing, so one is on order.
As the pamphlet says:
"No One Know Your GM Vehicle Better Than Mr. Goodwrench"
Asanti I do have the K&N E-1989 no clearance issues
I hope you aren't expecting it fixed soon... the wastegate solenoid is the part that is STILL on backorder for mine. Estimated date for shipment is MAY 31!. Luckily for me, the other part that they already replaced has mine running pretty well (see my won't boost past 13 psi thread).
Old Mar 29, 2010 | 09:33 AM
  #32
More_Torque_More_HP's Avatar
Originally Posted by asanti
So even the GM upgrade needs to be reflashed after installing a bigger IC + piping??? I don't have any other "tune" other than the GM Turbo upgrade... please enlighten an SS noob.
Also Peevlos: how'd you get the K&N to fit w/ the stock airbox cover? I assume you trimmed that plastic box underneath?
Thanks!
Allex
GMPP Upgrade does not require reflashing after an IC + piping install. A reflash of the same calibration won't change anything.
What may be happening is all the fueling adjust tables from the change in airflow takes time to learn their new requirements. A battery disconnect for 30 seconds will reset oll the tables to the nominal value. Re reflash since the software and calibration are reloaded does the same thing. So... if someone thinks a reflash fixed the problem it was probably the reset to nominal values in the tables that "fixed" the problem and that can be done by the battery disconnect.
Old Mar 29, 2010 | 10:43 AM
  #33
09 Silver Bullett's Avatar
So, with stock I/C and piping & stage 1 installed, battery disconnect will restore the higher boost levels I had after the upgrade was installed?
Old Mar 29, 2010 | 10:44 AM
  #34
gcsd3742's Avatar
Good answer all im saying is after the reflash mine worked like a charm. I have since then went and put H/P tuners on it as well and now I am boosting constantly at 24-28 PSI at all times. So what your saying going from the plastic to rubber hose configuration of the intercooler/piping to solid 3" polished stainless steel bigger circumfrence doesn't make a difference? can you please explain.
Thanks
Old Mar 29, 2010 | 10:47 AM
  #35
gcsd3742's Avatar
I just find that hard to believe but hey it's worth a shot....I found it was easier to go to the dealer. the Tech said said blah blah blah this and that was out of specs. I said reflash it and lets see.... He did back to like it was after install. But I also just 1 1/2 weeks ago cut out the butt splices soldered the wires directly and wow, a whole new car. Maybe you are having the same issue. I kept throwing overboost codes, after soldering wires on both upper and lower connections and heat shrinking them its all better.....
Old Mar 29, 2010 | 11:14 AM
  #36
The battery disconnect will reset the table values to nominal. If you mods have caused a skewing of the values and you have another change then disconnecting the battery for 30 seconds resets.
BTW this will also learn back in the mods on a non-stage kit turbo car. But the tune will then start learning back out the mods.
There are no changes in the flash/tune since it was introduced. So re-flashing won't correct any problems because you will be reflashing exactly the same tune you already have.
Old Mar 29, 2010 | 01:19 PM
  #37
asanti's Avatar
This is probably a stupid question, but here goes... Would disconnecting the battery erase any of the GM upgrade's programming? In other words, if I disconnect/reconnect the battery, would I lose any of the dowloaded flashes that were done when the GM upgrade was installed? I've always been curious, but felt too foolish to ask.
Later
Allex
Old Mar 29, 2010 | 01:22 PM
  #38
gcsd3742's Avatar
Later
Allex
I'd have to say NO it would just be like if the battery died. just plug n play a new battery....If it was then GM would be having alot of issues with dead batteries and cars not running no more just my .02 worth
Old Mar 29, 2010 | 01:28 PM
  #39
asanti's Avatar
Honestly I figured as much, but I guess I'm from the "better safe than sorry" camp I guess. Thanks!
Later
Allex
Old Mar 29, 2010 | 07:00 PM
  #40
87silver's Avatar
Later
Allex
Allex, what we're talking about here is the flash memory of the ECM. Flash memory is a type of electrically erasable and programmable read-only memory (EEPROM) (hence, reflash in regard to the upgrade). In the same manner, flash memory is used to hold control code such as the basic input/output system in a PC. This is why you don't lose the programming in your PC when you unplug it (desktop) or remove the battery (laptop). The same holds true when you disconnect the battery in your HHR SS.
