Anyone with Hahn 3" MODpipe?
Old May 29, 2011 | 09:44 PM
RobSSTurbo's Avatar
Has anyone installed one on there hhr ss yet? I like the cutout opt. myself.
Old May 30, 2011 | 08:54 AM
foolmoon_design's Avatar
I got both the DP and the 3" back.
$ for $ its pricey but the second best HP bolt-on, for the SS. (somewhere around 20HP)
HAHN's DP doesn't throw codes either, although to get the most out of it, you need to re-tune, especially if you add the cut-out. The Comp doesn't like a cut-out, or non-catted.
HAHN's 3" back comes with some T-Bolts, so you can drop the resonator section of pipe for the track, in less than five minutes.
We love it, just pray Florida doesn't start testing.
Old May 30, 2011 | 09:09 AM
RobSSTurbo's Avatar
If Florida does start testing(which is not anytime soon) I would just get the cat opt. That's why I like it, just seeing if anyone installed one.
Old May 30, 2011 | 06:50 PM
mitechman's Avatar
hahn downpipe
I have had the 3" Hahn downpipe (with hi flow cat) for over 6 months now- I actually had to take if off the first week because the power increase caused my stock clutch to start slipping when the boost got over 20 psi. I finally installed a Kentucky clutch and re-installed the downpipe. This is definetly a worthwile mod as it adds quite a bit of power although it will spin my conti extreme DW tires through 2nd gear now. This down pipe adds more exhaust sound too- I would say perfect as any more would be irritating cruising on the freeway. I really don't think replacing the muffler is necessary- you can see right thru it anyways.OH, and it has never tripped any check engine codes either.
Old Jun 1, 2011 | 07:52 PM
Chevy13's Avatar
Where is it for sale at?
Old Jun 1, 2011 | 08:42 PM
RobSSTurbo's Avatar
Here you go:
http://www.turbosystem.com/ProjectVe...%20MODpipe.htm
Ill be getting this hopefully soon then a e85 tune.
Old Jun 2, 2011 | 06:38 AM
Chevy13's Avatar
The Cobalt one is a direct hookup?
Old Jun 2, 2011 | 06:52 AM
NO. and make sure you order either a 5sp or auto version. The auto is about an 1" or so longer. If you buy from Aubry or Bill, and want a cut-out have them ship it with one.
Old Jun 2, 2011 | 10:30 AM
Chevy13's Avatar
Has it effected you MPG at all?
geg
Nov 25, 2020 12:52 AM
ChevyGuySS
2.0L Performance Tech
45
Jan 30, 2012 10:23 PM
kayakjax
21
Sep 29, 2011 09:11 PM
millerrdjr
Jul 28, 2009 07:39 PM
