Boost Controller
Old Mar 11, 2010 | 03:10 PM
JRGHHRSS08's Avatar
Boost Controller
Has anyone installed an aftermarket boost controller? If so where did you get it and was it easy to install? Thanks
Old Mar 12, 2010 | 07:42 PM
mistermike's Avatar
The wastegate is ECM controlled already. There's no need for an aftermarket controller.
Old Mar 13, 2010 | 12:17 AM
Jaxon's Avatar
actually there are people who have a boost controller and electronic boost controllers also because we cannot fully control the wastegate. I know there are a few people running them but you'll need a tune first to beable to make it work properly.
Old Mar 13, 2010 | 08:08 AM
mistermike's Avatar
If you can get into the E69 to re tune it, then you can modify the wastegate table, and still don't need the aftermarket controller.
Old Mar 15, 2010 | 08:15 AM
JRGHHRSS08's Avatar
So if i do not need an after market bc then how do i up my boost?
Old Mar 15, 2010 | 01:32 PM
asanti's Avatar
I believe a tune is necessary to up the boost. Either the GM upgrade, or an aftermarket tune like Trifecta, HPTuners, etc. IIRC, without getting one of those done 1st, any benefits you'd gain would be negated by the stock ECM anyway. I'm sure those with greater knowledge will chime in shortly.
Later
Allex
turbofreak
Mar 7, 2013 03:20 PM
GDZHHR
2.4L Performance Tech
Aug 5, 2011 09:23 PM
DoubleDocBrown
2.0L Performance Tech
Jan 11, 2011 01:48 PM
JRGHHRSS08
Nov 20, 2010 11:18 PM
