Boost Wanders
Old Mar 10, 2021 | 10:55 AM
Robert4's Avatar
Boost Wanders
Anyone have a place to point to if boost pressure wanders. Some times 18 other times 8lbs. Was working fine then slowly got worse. I was think 1 of the sensors. Thanks.
Old Mar 10, 2021 | 11:28 AM
Explain your reasoning to kill the messenger? Wouldn't a bad vacuum valve come to mind first?
Old Mar 10, 2021 | 12:00 PM
Robert4's Avatar
Hi, Are you talking about the actuator or that valve PN# 19168558. Which I have no idea what it does. First turbo car and I'm trying to get 160000 miles that are on it working like it was intended to.
Old Mar 10, 2021 | 03:36 PM
Could be a lot of things. That part number is the bypass valve, you could open it up and check the condition of the diaphragm. Check for vaccum/boost leaks(charge piping, vacuum tank, vacuum lines). Those are some starters that are free checks.
Old Mar 10, 2021 | 03:38 PM
2008 SS , I’d start looking at the piping and their connections, cracked intercooler that sort of thing, have a look at the valve at the turbo is that valve working? Perhaps the spring sprung
a lot of stuff in this thread
https://www.chevyhhr.net/forums/hhr-...t-56886/page3/
Old Mar 10, 2021 | 04:39 PM
I was just wondering why you might want to blame an innocent coil of wire embedded in epoxy before a worn out piece of rubber.
palolobill
Jan 4, 2021 07:39 AM
redss87
Apr 17, 2013 02:42 PM
DoubleDocBrown
2.0L Performance Tech
Jan 11, 2011 01:48 PM
JJ's BLACK SS
40
Apr 22, 2010 05:48 AM
hogwild
Feb 24, 2008 06:37 PM
