HHR SS Shutting off / Running rough for about the first few minutes each morning ?'s
all good questions
but no I definentley did not add any race gas
just been running the same gas from the same stations I get my gas from for my other cars.
93 octane 10% ethanol.
I have the file in Microsoft excel document
I did notice one other odd thing is that the car was running at like 200 and by the time I pulled over and it was running rough it was down to 186 degrees
I have never seen that car cool down that quick.
I'm thinking that you have an injector failing.
DI injectors fail in an 'open' position'.
So, if an injector is 'sticking' open, lots of fuel, with the O2 sensor 'seeing' it.
Also STFT seeing fuel too, & maxing out, in your log...
Water temp dropping, as lots of fuel has a 'cooling' effect...
But, you had said that you were having misfire codes for all cylinders,
could there be a sensor, or the ECM, 'telling' all the injectors, to go super rich ??
Originally Posted by Terminator2
Yes the car was commanding 14.0-14.7 but seeing in the 20s A/F wise so very lean even with the STFT being +30 which is as high as it can go.
'flakey' O2 sensor ??
Which would cause the water temps to go down because of the cooling effect of
the fuel dump' ??
His LTFT didn't have time change as quickly, in the log ??
Agree...
You can only do so much.
It's time to let the dealer figure this one out.
They have the proper test equipment, & resources.
Def sounds like a 'flakey' sensor, or ECM.
Water, &/or wire 'shorting issues, WILL degrade sensors.
O2 sensors can become 'flakey', & alot of guys just 'swap' them
out, after so many miles, or every two years.
Also bad gas, or someone putting something in your gas, used to
be a problem decades ago, not so much anymore.
Could you have mistakenly put 'leaded' race fuel, in the SS ?
I did purchase an extended bumper to bumper warranty
called dealer again asked if they could check sensors etc.
dealer pretty much said if car is brought in and when they get to it that day if the car is not running bad on the test drive then nothing they can do especially on a warranty issue.
looks like I have to wait till it does it all the time or I am wasting my time since the car does not do this everyday as of yet
if it was a bad ecm shouldnt it be throwing a code for that
not just the p106 and p101
So, does this mean that the O2 is 'flakey', going instantly lean, causing the STFT to instantly to +30, which means telling the injectors go full on to cure the 'lean' reading of the
the fuel dump' ??
the fuel dump' ??
Made up a better boost leak* checker and after spraying some soapy mixture on the pipes i did find what may be considered a minor or more* towards* a good size leak.
* On hot side pipe where it is crimped together from the factory where it goes from hard plastic to rubber.
will this cause this mess that I have been dealing with?
Quick update
Changed upper and lower tmap sensors which are much cheaper than the stock ones at least
Flipped tmap sensor 180 degrees
changed plugs even though they appeared to be in great shape I am glad that I got them out now at 60k.
Tmaps looked like the yellow part was bigger than the new ones going in.
I figured I would be throwing a code by now but car has been running great besides
throwing a couple of fan codes which I believe I have figured out.
i thought with the boost leak it would still be throwing codes
