I'm gonna get cold air into this motor or else!
Old Sep 7, 2011 | 09:07 PM
  #81
THE BATMAN's Avatar
The man is back in town ! Yes.
Old Sep 7, 2011 | 09:10 PM
  #82
Snoopy's Avatar
Wow, XXL...
Good to see you. Welcome back and where have you been...if you care to say?
Old Sep 7, 2011 | 09:11 PM
  #83
XXL's Avatar
XXL
Originally Posted by foolmoon_design
Wow, a 2 year old thread makes a come-back? XXl is still around on the fringes, but wow a 2 year old thread and not an update from XXL wow.
Someone gave me a pointer to this thread, requesting an update so...
I did complete my original design for pulling cold air from what used to be the fog lights (both sides have inlets, but I was actually only plumbed on the passenger side... never got around to trying to plumb the driver side). It worked well, never had issues that several expressed concern about-- water, dirt, squirrels, etc., being sucked into the system.
I had some logged data comparing between stock inlet and my CAI setup. However, those logs were lost in the Great USB-Drive-Into-the-Toilet debacle of 2010. What the data showed was that _something_ was allowing faster spool-up, so the power came on faster. My belief is that I was providing cooler, more dense air, which provided a bigger payload to the motor.
I have since reverted to a stock air intake setup, and have been trying to build a larger airbox (to ensure I can feed it enough air at all times-- 750cfm). That project, like so many others, is not progressing very fast. However, my setup has much bigger issues at the moment-- GM "kwality" in the electrical system, some mysterious mechanical issue whereby the solenoids don't properly manage WG and BPV operation, and, of course, waiting for that to be figured out, tuning. It will still smoke a stock SS in my neighborhood, even while dumping boost just as the power comes on hard. But it would still be nice to see the other 60-80hp that's blowing out the WG . I have been unable to find anyone in the area who has the knowledge to help solve these problems, and while there are several people who have always been very helpful, it's almost impossible to debug such problems over the Internet.
Old Sep 7, 2011 | 09:12 PM
  #84
lunchbox's Avatar
For real, it's been a while
I too ran the intake from the fog light hole, but mine goes to a supercharger
Old Sep 7, 2011 | 11:34 PM
  #85
moonsign's Avatar
As in one of my earlier post[w/pics.] I have been running a large hood scoop, cutout to dump loads of cool air ,over my airbox lid cutout, over the filter, for awhile now. No problems, no codes, and the big scoop is dimping lots of cool air under the hood, and into the filter area. Seems to be making a big difference, from stock setup. Only thing, it definately makes a loud sucking sound during boost, and the BOV is really loud now. You can hear it a block away. "Moon"
Old Sep 8, 2011 | 12:01 AM
  #86
MOON a block.... really ?? It sucks in prizes at the car show too!!
Old Sep 8, 2011 | 04:48 AM
  #87
foolmoon_design's Avatar
XXL, Welcome Back!
You say your bleeding boost? or is it deliberately dumping it? Only at the drag strip, do I notice a huge dump, and a sharp "tweet". This only occurs to me after leaving the water box, tires spinning away, then instant grip. since we have a by-pass took me by suprise first time I heard it.
Old Sep 8, 2011 | 06:03 AM
  #88
ATLsilverSS's Avatar
are you tuned? if not, have you done any logs to see if the increased airflow is skewing your fuel trims?
Old Sep 8, 2011 | 08:11 AM
  #89
pappa_smurf's Avatar
Red face Try driving through the mountains.
On my cross country road trip, with the cruise set @ 80mph, going up and down those mountains was really noisy. The downhills were the worse. When ever the boost got down to @ 8-10 in Hg (on the vacuum side) the BOV would open up and you would get what a lot of the people in this forum have reported as that clunking noise from the turbo. It feels like an Auto Tranny downshifting. Got used to it after about 10 times though. Then on the up hills the boost would climb to @ 10 psi. This without even touching the gas pedal.
But seriously, why the need for a CAI on a Turbo? You're just wasting gas for that momentary thrill of acceleration and shortening the life of the turbo. Not a practical mod for street use. Just my two cents.
Old Sep 8, 2011 | 12:13 PM
  #90
JeramieJJ's Avatar
just use methyl injection when you want the power, flip on a switch.
- No cutting, alterations or creating of exotic pieces for some uncontrolled cold air.
- Methyl increases your gas octane.
- Methyl lowers your cold air charge temps after the blower....much better than hoping those cold air temps help once heat soak is in place.
- Use a three nozzle system, you can cool your blower itself, extending its life and lower the air charge temps.
Get a decent system.......such as http://www.alcoholinjectionsystems.c...duct_info.html
