I'm gonna get cold air into this motor or else!
Old Sep 26, 2009 | 10:10 PM
XXL's Avatar
XXL
Started cutting today...
One side of the inlets roughed in.
Last edited by HillsdaleHHR; Sep 27, 2009 at 06:16 AM. Reason: Reduced pics to max size 640 x 480!!!
Old Sep 26, 2009 | 10:17 PM
Ratracer's Avatar
You're a brave and adventurous soul. I had pondered this very thing, but couldn't bear to lose the fogs.
Old Sep 27, 2009 | 12:43 AM
damronjr's Avatar
IMO, probably the best place to do it as there is no restriction or any blocking of airflow. Fog housing should provide a good funnel to push the air in. Keep us posted, I want to see how this turns out! I would like to see a lot more pics of your ride and the things you have done to it.
Old Sep 27, 2009 | 01:56 AM
HipHotRod's Avatar
You guys are talented and getting close. There was another recent idea posted here that had some real potential as well. This is good stuff, I await anxiously.
Old Sep 27, 2009 | 08:51 AM
SOMBERSHARK0714's Avatar
same here.
Old Sep 27, 2009 | 09:00 AM
harleysshhr's Avatar
It's getting cool!
Old Sep 27, 2009 | 09:56 AM
JoeR's Avatar
I know that I'm just a 2.4 guy, but when looking at the pic of the outer "grill" that houses the fog lights, I think....
This would take time and patience, but what if you cut out the back part of the diamond pattern, leaving just the outer grill part? That would keep the appearance stock yet open up a lot of airflow area. Just keep in mind of what may happen during very wet driving conditions. The MAF does not like water.
Old Sep 27, 2009 | 11:46 AM
c2vette's Avatar
Just opening that up the way you have done, even without any further ducting I would think would get more cold air into the fender well area that the intake draws air from. Like others, I pondered the same thing but could not figure out where the fogs would go. Good job though.
Old Sep 27, 2009 | 02:32 PM
xzombiex66's Avatar
I have been pondering this idea for some time now, good luck!!
Old Sep 27, 2009 | 03:06 PM
RaineMan's Avatar
I've seen a couple of Ion RedLine guys cut out the plastic in their mesh grilles for more airflow. It takes a few hours with a dremel... but it can be done.
