Intercooler piping
Old Nov 30, 2012 | 08:00 PM
XtremeSS's Avatar
Originally Posted by Temple of Zoom
Will the 3 bar GMPP sensors work with the CIA piping without any modifications? I thought I may have read somewhere that the GMPP 3 bar sensors wouldn't work with the CIA piping unless they specifically built it for the GMPP sensor?
I had to flip mine 180 degrees from the normal position to make it fit right. the clearance looked like this:
It worked fine and with just enough clearance. Got bored one day and decided to make more clearance "just in case". So I fabricated some longer radiator mounts to give about 3/4 inch more clearance. This was the result:
Fabricating new mounts is not needed with the lower CIA charge pipes, but the extra clearance is nice. Just flip the sensor 180 and it will b good.
Old Nov 30, 2012 | 08:04 PM
Chevy13's Avatar
Hahn is aware of the GM upgrade sensors due to installation of the piping on my car in his shop. It shouldn't be an issue as along as you let him know that's what you have
Old Nov 30, 2012 | 08:53 PM
XtremeSS's Avatar
Foolmoon has Hahn pipes and he had to flip his 180 to make it fit also. I know he got his a while ago. Hahn may have had an updated set of charge pipes. When did you get yours?
Old Dec 1, 2012 | 06:33 AM
foolmoon_design's Avatar
Yeah, I had no choice but to flip the sensor, but it has been running fine this way for years. Im actually happier it is reversed. More wiggle room
Old Dec 1, 2012 | 06:34 AM
I also added some brackets at bottom of radiator with 1/4"x1" flat bar
Old Dec 1, 2012 | 12:06 PM
Chevy13's Avatar
Just a couple of months ago. He designed a new pipe during the install after seeing the issue of how the pipe fit with the upgraded sensors.
Old Dec 1, 2012 | 12:44 PM
Evad's Avatar
I just ordered a set of Hahn IC Pipes last week. I'll give them a call Monday to be sure that what they are going to send me will clear the 3-Bar sensor.
I'll let ya know what they say about this matter.
Old Dec 1, 2012 | 03:21 PM
XtremeSS's Avatar
Very cool. Do you have any pics showing clearance and location of the map sensor?
Old Dec 1, 2012 | 09:19 PM
Miltown SS's Avatar
Don't buy hahn
I bought a set of Hahn charge pipes about a month ago and the lower pipe did not fit at all. I had the pipe installed at a reputable tuner shop and they had to cut the end off the pipe and fab a new piece. Hahn customer service IS NON EXISTENT. After several weeks of being ignored with their tech ticket system I called and spoke to a sales person who said he would forward my email to Bill personaly and guess what NOTHING! Hahn is a joke with no way to get a hold of them if something goes wrong. Just sayin beware if you go the Hahn route the parts might not even fit and then what are you supposed to do when you paid someone to take apart your car? I wish I had taken recommendations to go the ZZP route. I have the Hahn intercooler as well and they don't even supply stronger intercooler mounts.
Old Dec 2, 2012 | 01:22 AM
Omnigear's Avatar
hahn is overpriced to begin with >_<
