Loss of power after Stage Upgrade
Old Jan 13, 2009 | 03:45 PM
Urban Legend's Avatar
HOLY F*IN SH*T!!!!!!!!!!!!!!!!!!!! damn this car has power now. its 40 degrees out and i just picked it up. on the way home i managed to spike 25-26psI on several occasions! but everyones right when they say no traction in first or second. first at half throttle there is no grip in second at half there is some but not much.
and to *rosieandelton* they will put it in for you if you'd like. I spoke to the tech today about what was wrong and he said it was just the wiring. he went home last night and researched it himself till he found what he was lookiing for. and today i am 1 happy motorist! if you would like to call them the number is (732) 907-1564 and just ask for service dept. My name is Joe Urban, just in case you need to reference me but good luck, you'll absolutely love it!
gtg out driving! enjoy the night people!
Last edited by ChevyMgr; Jan 13, 2009 at 05:08 PM. Reason: mild edit on excitement
Old Jan 13, 2009 | 05:10 PM
ChevyMgr's Avatar
LMAO, looks like you are a happy customer now. Funny how our emotions change from one day to the next.
Old Jan 13, 2009 | 07:44 PM
turbofreak's Avatar
[QUOTE=Urban Legend;348285]HOLY F*IN SH*T!!!!!!!!!!!!!!!!!!!! damn this car has power now. its 40 degrees out and i just picked it up. on the way home i managed to spike 25-26psI on several occasions! but everyones right when they say no traction in first or second. first at half throttle there is no grip in second at half there is some but not much.
Let us know if you continue to have 25 psi boost. That is 3-4 more psi than
other stage 2 cars are seeing. They do run crazy fast at 25 psi.
Did u do the waste gate mod before the install??
turbofreak
Old Jan 13, 2009 | 08:04 PM
mightymouse's Avatar
it will go down after a few days of driving to 20-22psi...they all do lol.
Old Jan 13, 2009 | 11:20 PM
oh man do i love it! my mood def. changed. and yes i did do the wastegate mod. i totally forgot about that! i hope it stays at 25 PSI this thing HAULS in third. i absolutely love it. if your thinkin about takin the plunge then i can assure you that it is definately worth it!
Old Jan 14, 2009 | 01:59 AM
IgottaWoody's Avatar
Hmmmmmmmmmmmmmm
Old Jan 14, 2009 | 07:26 AM
turbofreak's Avatar
I suggest you carefully try a WOT test in 5th gear at about 3000 rpm or 4th at about 3500 rpm and check if clutch slips. Mine at 25 psi slipped and I had to back off some on WG mod.
turbofreak
Old Jan 14, 2009 | 11:43 AM
ChevyMgr's Avatar
There is a new Technical Service Bulletin on issues after the install. See it at:
https://www.chevyhhr.net/forums/show...727#post348727
Old Jan 14, 2009 | 12:05 PM
DrLoch's Avatar
turbofreak
Is that sort of like, Doctor if I move my arm around to this position it hurts, to which the doctor says, well then don't do that?
Old Jan 14, 2009 | 01:27 PM
turbofreak's Avatar
Exactly, I was running 25 psi with Westers race tune. Now I have a GM stage
tune. Also have HPT so I can change at will after Lyndon retunes the GM tune.
The boost hits alot slower on the GM tune. The Westers hits with a rush.
The GM tune hits softer on a purpose tohelp protect parts. Thus the low rpm
on aftermarket is stronger but both are strong above 3500 on up.
BUT and it is a BIG BUT, the GM tune does not cause the clutch to slip in
4th or 5th gear. The boost is less than race tune but when the aftermarket
was lowered to similar boost as GM, the clutch still slipped- again I feel due to
how hard the boost hits. I believe the aftermarket can be modded to have best of both worlds. Before with race tune, I just stayed away from WOT
at the 3200 rpm range unless I downshifted.
