Low Boost
Old Jun 18, 2014 | 11:55 AM
15-18 lbs would be normal for a stock SS.
Not really sure what you mean in this sentence :
" is that the cars getting 15-18 pounds of boost were calibrated that way from the factory and my car was not"
So, are you getting the normal 15-18 and your gauge was only showing 10 ?
Or are you saying the dealer said your car is calibrated to only 10 lbs.
If it is so called "calibrated too low" then a simple GM reflash of the computer would do the trick.
Fwiw. I don't think there is a GM flash or reflash with a setting of 10 lbs.
You may want to rewrite your post to make it more clear.
Old Jun 18, 2014 | 11:56 AM
mrchevy's Avatar
Originally Posted by sinabu
While it does seem low.
I'm curious as to what kind of HP/TQ numbers are you seeing. Does yours have the RPD?
I do have the RPD but to be honest I have never looked at either but I will now as soon as I pick the car up
Old Jun 18, 2014 | 12:24 PM
sinabu's Avatar
I'm just curious as to what kind of HP/TQ numbers your getting.
Before the tune mine struggled to hit 15psi. 10-12psi was my norm but I was hitting my HP close enough to not warrant any issue.
After the tune I'm getting 15-17 Normally while others are getting upwards of 20
Old Jun 23, 2014 | 03:43 PM
mrchevy's Avatar
will sorry to say its still at the dealership but I will check HP/TQ as soon as I get it back their waiting on a brake control module for the brake issue I was having took them a while to diagnose that
Old Dec 21, 2014 | 08:20 AM
sinabu's Avatar
Hey Mrchevy, Did you ever get a resolution on your issue? Would be interesting to hear the results
Old Dec 22, 2014 | 08:42 PM
Cat Man HHR's Avatar
I'm curious also.
I've never looked at the boost at full throttle to see what it was, wanting to keep my eye's on the road. I have seen 10lb at about 3/4 throttle on a flat road.
It's been said you can use the RPD to see HP/TQ. Can I get some insight on this?
Old Dec 22, 2014 | 08:47 PM
Here you go Cat Man. HP is on the analog dial gauge. Torque reads on the digital readout.
Old Dec 22, 2014 | 09:02 PM
Attachment 16795
Thanks going to have to look at that. My scanner can take a snap shot while I'm driving to see the numbers instead of trying to look at the RPD.
I have an AutoXray AX7000 Scanner which gives me real values while the engine is running. I have taken a few when programming the ECM in my 83 TPI Monte Carlo. I don't burn chips with this ECM, I go in with a laptop and can change parameters.
foxtrotraptor
45
Aug 10, 2013 06:00 AM
redss87
Apr 17, 2013 02:42 PM
Nazgul 9
Dec 1, 2012 04:10 PM
ssdivin
Apr 26, 2011 06:55 PM
ecopower02
2.2L Performance Tech
27
Aug 14, 2006 09:09 AM
