new dyno numbers...
Old Aug 10, 2010 | 02:07 PM
Jaxon's Avatar
Originally Posted by Jaxon
Quote:
Originally Posted by TomsHHR
The Trifecta tune can bring you above 315 without "bolt ons".
Maybe on a dyno that reads too high. A stock LNF with 30psi cant do 315whp, maybe over 400wtq with a clutch, but the stock turbo with all stock parts just wont support the HP. The stock turbo just doesnt have the efficiency needed for that.
See what I mean?
Old Aug 10, 2010 | 02:42 PM
bartSS's Avatar
With a tune only the car wont be at 315whp and if it is then youre boosting a bit too high and will need intercooler piping soon when yours goes pop lol
Old Aug 10, 2010 | 04:15 PM
Jaxon's Avatar
The turbo will just fall off power up top, it wont boost 30psi at redline lol. Like I said before, it could make a ton of torque with a ton of boost, but not the HP.
Old Aug 11, 2010 | 01:20 PM
mightymouse's Avatar
okay jax,sorry. yeah tune only maybe 285-290ish on the high side. probably 275ish on the lower end and that's assuming they have an upgraded clutch.
Old Aug 11, 2010 | 02:07 PM
Originally Posted by HHRSSouth
My vote is around 315 whp. take your HHR SS to a Dyno jet dyno and see what you get (should read higher then the Dynocom) or find another Dynocom and compare.
just curious to why 315hp? is that a high side guess or low side guess? just asking,don't mean to sound like an ass,just really want to know. maybe you know something i don't.
bone stock was 247
hahn tune was 263.
now,the car was never on a dyno till recently. before this last pull,this is what was added to the car.
3inch DP/EXHAUST NO CATS* good for 20hp *no cats is still better than a catted DP,period. which will give a little more hp.
bigger front mount and ic piping and yes it was a noticable difference 10-15hp.
upgraded to a st 3 clutch-not a hp gain,but helps with holding the power and not letting it "slip" away.
now the rule of thumb(roughly) every psi of boost is equal to 6-8hp.
multiply that x5 which is about 30-40more hp.(i'm boosting 25psi).
add it up
247-stock
20-exaust
15-IC
40-tune
322ish-going by on paper-the low side would be 307ish(minus 10 for the tune and 5 for the IC.)
want to do it again on the same dyno,with cooler temps. everytime the car was on a dyno,it was 98-100degrees with a heat index of 103.
Old Aug 11, 2010 | 11:36 PM
  #26
Jaxon's Avatar
A catless wont give you 20hp, maybe 15hp max. Also, the clutch should easily hold 320whp, its the 350+ wtq that it has a problem with. Its not so much that its the clutch, its the pressure plate that just can't handle the torque. There are cars with upgraded turbos on stock clutch putting close to 400whp/400wtq on the stock clutch, just because they get their power higher up in the RPMs opposed to making 350+wtq at 2500rpm lol.
Old Aug 12, 2010 | 08:17 AM
  #27
HHRSSouth's Avatar
bone stock was 247
hahn tune was 263.
add it up
247-stock
20-exaust
15-IC
40-tune
Why on the earth would you want to dyno again on the same dyno? We've already established the dyno is wrong (this points not even up for discussion really). The only thing the same dyno would be good for now, would be comparing parts that you upgrade to the previous dyno session.
If you want an accurate dyno reading of what your car is putting down you will have to go else where for a dyno session. Ask some enthusiast in your area and find out the most accurate dyno. If you want infalted numbers I guess keep using the same dyno.
I prefer conservative dynos myself so I know the minimum whp, wtq I might be making.
Thats what kills me about having a dyno list on some automotive forums, you could go to highest reading dyno in the area, get infalted numbers to try and make your car look good.
Old Aug 12, 2010 | 08:57 AM
  #28
Rainman's Avatar
I've taken mine to the same dyno every time, it's the same one that all the local sprint cars, modified teams and Vince from Trificta tunes uses. Right know I'm at 276whp and 287 fpt which works out to approx 315 hp to the flywheel, thats with all my current mods, that was run by Vince, the only reason I haven't added the trifecta tune is at the time he wasn't done tweeking it and I haven't had the time since, plus I believe we'll need to change the clutch to do it any justice.
ssdivin
2.0L Performance Tech
Jul 20, 2011 01:04 AM
hhrss09
Nov 20, 2009 05:07 PM
JAXFL_SS
Aug 31, 2009 07:57 PM
REDFOCZ
2.4L Performance Tech
Dec 1, 2007 11:16 PM
