Old rookie I got to start somewhere!
Because i know little about these high tech turbo charged complicated engines my question is how does one know if my SS has a High performance tune?
It has some modifications like INJEN tuned air Intake system a MPX intercooler and more I've had it since 2012 I just didn't drive it much now that I am retired
I drive it more and its addicting so its time for me to learn what I can so I can speak your lingo, LOL
Thanks
JD...
Thanks
JD...
In HHR SS speak, the fuel door should have a sticker indicating high octane fuel is required , the sensors will be blue with Bosch embossed on them.
As for an aftermarket tune, I have no idea
That might be the number from Bosch...
What's in the box:
1 - 11589015 Bolt Tmap Sensor
2 - 88988320 Connector Sen-MAP w/ leads
1 - 12602863 Sticker Premium Fuel
1 - 12626987 Label Cert
2 - 12626998 O-Ring T-MAP 18533
2 - 55206797 Sensor T-MAP
1 - GM Performance Decal
1 - 19212711 Instruction Sheet
from AbleCommerce: Software that Sells!(TM)
What's in the box:
That was alot of good info "Old Blue" I will read all of it I am having problems with cel codes I took car too a good auto shop 3 weeks ago they replaced my clutch (CLUTCH KIT) and I wanted them to inspect it too. They said I need to drive it more to complete any incomplete monitors so on way home i got a cel warning I checked it with reader and had 2 codes p2261 and p2187 they said to clear codes then do drive cycles which I did 4 or 5 times now I have 4 codes and 1 monitor P2261, P2187, p0420 p0101 anyway I'm on a mission to figure it all out. LOL
Thanks
JD...
Thanks
JD...
Read through these
https://www.yourmechanic.com/article...-jamahl-walker
https://www.yourmechanic.com/article...by-elan-mcafee
https://www.yourmechanic.com/article...by-john-nelson
now read these all the way thru! Note common related issues, electrical connections, and loose parts or exhaust system leaks.
and by the way it’s Oldblue, not two words , just saying!
I will read them all and thank you for the help Oldblue I appreciate it if I get good at this diagnostic stuff maybe I will write a song called Oldblue LOL
Thanks again
PS.1st verse: I was taught by a man I never met or knew a very wise man and they called him Oldblue
(its a start LOL)
Thanks again
(its a start LOL)
I was taught by a man I never met , a man that was on the internet and they called him Oldblue.
He was the the administrator of a site, it’s strange but true,
chevyhhr.net , yep, that’s him, Oldblue!
Now we can’t forget Donbrew and RJ , they came to the rescue,
then there’s firemangeorge, and sleeper too,
I love these HHR’s is true, I don’t know about you!
use any of that you like, now if you record it and sell it, please donate any proceeds from my portion to the American Red Cross.
Thank you, Thank you, very much!
