Stage 1 Randomly kicking back to Safety Mode 2008 HHR SS
Old Aug 25, 2009 | 02:15 PM
Ratracer's Avatar
A problem was located. Seems the the lower boost pressure sensor wire came in contact with the a/c compressor under load intermittently and wore through the jacketing, grounding it out and causing false readings to throw the P0236 soft codes & intermittenet safe mode operation.
They repaired and rerouted the harness, so we'll see if this holds up.
Old Aug 25, 2009 | 06:05 PM
ATLsilverSS's Avatar
is this lower boost sensor located on the lower ic pipe coming from the ic to the intake manifold?
Old Aug 25, 2009 | 06:57 PM
camaro98z28's Avatar
Originally Posted by ATLsilverSS
was that the cause of your surging?
Wiring losing voltage between the connections. Even the tech was wondering why they dodn't say to use solder or why GM just didn't make a complete plug in play kit. I've had no other issues since the solder.
1ksprint
Jul 3, 2014 06:45 PM
blue car
2.4L Performance Tech
0
May 17, 2010 05:59 PM
hyperv6
2.0L Performance Tech
30
Apr 1, 2009 07:54 AM
stan1love
Jun 6, 2007 09:50 AM
