Vendor Rant!!!
Thanks for the 2 cents, but you may have missed the point. It's not how long we're waiting for the aftermarket to support the car... it's how long we're waiting for companies that SAID THEY WERE RELEASING PRODUCTS to actually do so.
It's not like the exciting moment when you finally got high speed Internet access after years of dialup. It's like the month after month of the company telling you it was going to be available, only to not make it available.
Here's your change...
You mean like how it was about a year after the initial release date of the GM stage kits for the LSJs before it finally got out there? It happens...you have people interested in the LNF...progress is progress.
Yes, and so since GM set the bar so high, we, as consumers should just STFU and get over it (instead of expressing our dissatisfaction and voting with our feet)? Good plan. That'll get them to step up.
I'm doubting if major players in the aftermarket really want to invest time and money into a body that will change in about 2 years....especially with the relatively low volume of owners who wish to do "radical" changes to the body (other than stickers,etc.).
Aftermarket engine changes/parts would be nice since the Ecotec appear to be around for awhile. But then engine compartment size/changes enters the equation and re-engineering again needs to be done by them.
Dyno numbers with 3" exhaust and off road downpipe.
FOR OFF ROAD USE ONLY!
"Alot more torque and a little more power"
Dynojet Research Inc.
Run Name: G:\Documents\ADM TUNES HHR SS\HHR SS\HHR SS\DYNORUN.008
Run Title:
Run Notes:
STOCK TUNE WITH ADM OFF ROAD DOWNPIPE AND CAT BACK EXHAUST
DYNORUN.008: 85.73 °F 29.70 in-Hg Humidity: 13 % SAE: 1.00
s RPM x1000 hp ft-lbs
0.54 3.10 118.48 200.72
0.87 3.20 146.24 239.99
1.17 3.30 168.46 268.10
1.45 3.40 181.26 279.99
1.74 3.50 187.76 281.77
2.02 3.60 193.81 282.76
2.30 3.70 202.97 288.12
2.58 3.80 208.35 287.97
2.87 3.90 212.52 286.20
3.15 4.00 214.86 282.13
3.45 4.10 219.42 281.07
3.74 4.20 221.66 277.19
4.05 4.30 222.41 271.67
4.36 4.40 222.62 265.73
4.66 4.50 226.76 264.63
4.99 4.60 228.45 260.84
5.30 4.70 232.74 260.14
5.61 4.80 238.26 260.67
5.94 4.90 241.07 258.21
6.24 5.00 249.63 262.42
6.56 5.10 254.40 274.23
6.89 5.20 252.89 255.22
7.22 5.30 254.76 252.04
7.56 5.40 250.30 240.77
7.90 5.50 251.14 237.21
8.27 5.60 245.31 229.79
8.64 5.70 239.69 220.75
9.04 5.80 234.24 212.11
9.45 5.90 230.48 205.21
9.88 6.00 223.23 195.40
10.31 6.10 231.28 199.14
10.77 6.20 217.21 184.00
11.31 6.30 198.63 165.59
MAX: 11.31 6.30 254.76 288.12
MIN: 0.54 3.10 118.48 165.59
WE DID TURN OFF THE REAR 02 CODES FOR THIS TEST.
STOCK NUMBERS:
Run Name: G:\Documents\ADM TUNES HHR SS\HHR SS\HHR SS\DYNORUN.001
Run Title:
Run Notes:
DYNORUN.001: 78.40 °F 29.44 in-Hg Humidity: 27 % SAE: 1.00
0.63 2.50 83.35 175.10
1.01 2.60 102.92 207.88
1.36 2.70 119.65 232.74
1.67 2.80 133.28 250.00
1.98 2.90 142.26 257.64
2.30 3.00 145.85 255.34
2.61 3.10 150.11 254.32
2.93 3.20 153.49 251.91
3.25 3.30 158.18 251.75
3.57 3.40 161.82 249.97
3.90 3.50 163.27 245.01
4.24 3.60 168.21 245.41
4.57 3.70 171.14 242.93
4.90 3.80 175.93 243.17
5.24 3.90 180.47 243.04
5.57 4.00 184.14 241.78
5.91 4.10 187.97 240.80
6.25 4.20 194.07 242.68
6.59 4.30 195.60 238.91
6.94 4.40 197.91 236.23
7.28 4.50 200.43 233.93
7.64 4.60 203.93 232.83
8.00 4.70 206.91 231.21
8.35 4.80 212.24 232.23
8.71 4.90 215.63 231.12
9.06 5.00 220.45 231.56
9.41 5.10 228.69 235.51
9.76 5.20 231.06 233.38
10.12 5.30 235.17 233.04
10.48 5.40 238.77 232.23
10.84 5.50 240.68 229.84
11.20 5.60 242.88 227.78
11.58 5.70 245.00 225.76
11.97 5.80 240.94 218.18
12.38 5.90 235.69 209.82
12.80 6.00 234.51 205.28
13.23 6.10 231.97 199.73
13.67 6.20 230.07 194.90
14.20 6.30 213.33 177.85
MAX: 14.20 6.30 245.00 257.64
MIN: 0.63 2.50 83.35 175.10
Run Title:
Run Notes:
STOCK NUMBERS:
Run Title:
Run Notes:
