What Downpipe to order?
Old 06-23-2014, 10:39 AM
T-Rodius's Avatar
So I've got an 08 Auto that's currently in the shop awaiting parts for the ingnition. A few days prior to taking it in I noticed what sounded like some sort of air leak coming from the exhaust manifold. Had them take a look at it and was told its the cat that's leaking. So my thoughts are to just order a DP and do away with the cat. Took a look at ZZP online, just not sure what the available options are at checkout when ordering the part. Anyone have any insight or recommendations? Thanks.
T-Rodius is offline
Old 06-23-2014, 11:58 AM
Beachbum1's Avatar
you might try contacting Rock Auto,that's where I got mine. It wasn't the cat leaking, it was the down pipe. got a replacement and took it to a muffler shop and they welded it on. no leak and very good job.
Beachbum1 is offline
Old 06-23-2014, 01:29 PM
jczboy's Avatar
If you are not tuned, be prepared for a P0420. I know for sure you can by-pass the code with a Trifecta tune. Not sure of the others.
Personally, I would remove it, get that one repaired. Then core the 2nd cat. I have a catless DP on my toolbox, wasn't a good way to go for me. Even turning off the light through the tune.
Good luck
jczboy is offline
Old 06-23-2014, 04:50 PM
T-Rodius's Avatar
I've got the Trifecta tune
T-Rodius is offline
Old 07-01-2014, 07:54 AM
fiveothis's Avatar
Good luck
Why was the catless downpipe not a good way to go???
fiveothis is offline
Old 07-01-2014, 02:07 PM
I have a ZZP high flow auto catted down pipe still in the box. I decided to keep the stock one since we have emission testing, PM me if you would like to give it a try.
SS fan is offline
Old 07-01-2014, 02:08 PM
jczboy's Avatar
There was no power gain, and a flat spot in the mid range. Coring the 2nd cat seem the best way to go. (It did sound kind a cool though) PM me in your interested in a catless DP
jczboy is offline
Old 07-05-2014, 01:51 AM
XtremeSS's Avatar
If you want to avoid CEL, the ZZP 400cell catted DP would be the way to go, or sourcing a stock DP and core the 2nd cat yourself.
If you want the most hp and are willing to tune around a possible CEL then go with the 200cell catted or catless with angled bung.
I run a 300 cell cat in my CIA DP and never got a CEL even before i was tuned. I also chose a catted DP because I didn't want the exhaust to be much louder.
XtremeSS is offline
Old 07-06-2014, 11:13 PM
gamma-wes's Avatar
Any pipe you get is going to tweak your power-band. There's a few things that you can do to get rid of a CEL/MIL. First is to add resistance to the O2 sensor. There's a formula to compute what you need, but I don't have it off-hand. The next is the no-fouler solution. Not pretty, but it works more than it doesn't.
gamma-wes is offline
Old 07-20-2015, 04:49 PM
Johnny Switchblade's Avatar
Will the ZZP catted 400 cause CEL on my bone stock 08? I was looking for better sound and a few HPs but the info on DPs has been mixed to say the least.
Johnny Switchblade is offline
Quick Reply: What Downpipe to order?
