View Poll Results: which tune do you have???
hahn/bsr
20.83%
hptuners
12.50%
gm tune
14
58.33%
gm/hpt
8.33%
Voters: 24. You may not vote on this poll
what tune do you have???
Old Dec 25, 2008 | 06:01 PM
mightymouse's Avatar
Originally Posted by turbofreak
I will be eagerly waiting on your report on the Spec clutch. I am only seeing trouble above 21 or so psi in higher gears. Can run 23-25 psi even now in
winter in lower gears.
What are u running with PPC and hahn IC for boost level and at what level
did your clutch act up??
I got the shop manual and looks like to do clutch you need to support
engine, disconnect axles & susp, drop frame for access to trans, then drop
trans to change clutch. It may be possible to get trans to disengage enough
to do clutch without removing frame. Maybe ChevyMgr or someone with
experience can comment.
turbofreak
with the ic and piping i'm hitting 22 and falling to 20. yeah,i'm having the same slippage as you are. 4th and 5th it slips above 20psi. 1-3 no issues...yet.
hhr_2009
2.2L Performance Tech
11
Jun 23, 2013 10:56 PM
RJohn
2.0L Performance Tech
Apr 16, 2013 09:04 PM
yellowjacket
Aug 31, 2012 09:02 AM
kishasara
Maintenance and Upkeep
Oct 13, 2010 09:20 PM
joe o
Mar 17, 2010 03:51 PM
