ZZP FULL INTAKE, bring 'em out.
Love the downpipe. Nice bark to it when you get on it. No drone under normal load. I do get a code every now and then, but it goes away in a day or so.For the first couple of days, I had a noticeable increase in power (butt dyno), but until I get tuned, I guess I won't get that back.
BTW....I'm way happier with the intake now. I had the Trifecta Tune removed (reflashed my ECM with the GMS1 tune) and now I have NO codes at all. With Trifecta....I was getting nothing but P0101 and P2199 codes allllllll the time.
How are you getting 24psi with the GMTU? The most I have seen with the GMTU is 20 maybe, usually around 19 or so. You must be right at sea level?
The MAX I got out of the car STOCK was 18 psi.
http://www.youtube.com/watch?v=79lfV...8&feature=plcp
Damn, if i didn't get another CEL today. So, I followed my usual pattern and pulled the neg cable on the battery to reset it. This worked, so I thought. Just as I get home tonight, the CEL comes back along with....ENG PWR RDCD! uggh..I can't get it to clear.
I've read horror stories of damage caused by daily driving in limp mode
See my other thread, but this may not have anything to do with the intake. The code was/is P0087 - Low Fuel Rail Pressure. Its at the shop right now.
By chance did you look at your plugs?
I had replace my regulator at 34k , oddly enough this happen within 1000miles of me using a kn cone filter in stock air box. So returned to factory element and towed to dealership
Tech their told me to not seafoam the Motor. No clue how he knew but I took his advice lol
