ZZP FULL INTAKE, bring 'em out.
Old Apr 4, 2012 | 03:17 PM
  #181
JAXFL_SS's Avatar
I didn't look at the plugs. I just checked the basics, then it started raining last night. Called the dealer this morning.
Just heard back. They are replacing the HPFP under warranty. Picking up the rental here in about an hour. Should have Red back by the weekend (I hope).
Old Apr 4, 2012 | 03:51 PM
  #182
KissMy08SS's Avatar
Mine threw a P0101 and went into limp mode as well. I only have the GMS1 tune on it. Ohhhh well....another reason for HP
Old Apr 4, 2012 | 04:11 PM
  #183
foolmoon_design's Avatar
Originally Posted by Miltown SS
How are you getting 24psi with the GMTU? The most I have seen with the GMTU is 20 maybe, usually around 19 or so. You must be right at sea level?
Again, its about killing the learn down.
GMTU should get you 21psi
everything else stacks on that. with cat-less, IC, Piping, and intake. 24+ is sort of normal.
Old Apr 4, 2012 | 04:20 PM
  #184
XtremeSS's Avatar
Had nothing but gmtu on my 09. Saw 24psi 90% of the time.
Old Apr 4, 2012 | 04:43 PM
  #185
Turbo Hearse's Avatar
Originally Posted by EcotecRacer
By chance did you look at your plugs?
I had replace my regulator at 34k , oddly enough this happen within 1000miles of me using a kn cone filter in stock air box. So returned to factory element and towed to dealership
Tech their told me to not seafoam the Motor. No clue how he knew but I took his advice lol
Did he give you any reason NOT to seafoam?
Old Apr 4, 2012 | 05:19 PM
  #186
EcotecRacer's Avatar
I was more curious how he knew I seafoamed to be honest
He just advised against it for DI systems and I didn't want admit using and lose warranty either
Old Apr 4, 2012 | 10:56 PM
  #187
That's weird. EVERYONE on css.net is huge on seafoaming every like 25k.
Old Apr 4, 2012 | 11:19 PM
  #188
I was one of those people
Spoke Jon Powell and he agreed with my tech,he mentioned GM had change their fuel and injector cleaner service for DI ....I dunno but I trust Powell
I then asked couple high level ls oriented shops and they said it can't hurt but neither shop believed in it....
Old Apr 17, 2012 | 09:31 PM
  #189
SCE_HHR's Avatar
You should see less boost with those mods not more. But I don't know how the gms1 tune is set up so I may be wrong. If the tune stays constant and doesn't adapt to the mods then you end up with less restricting and seeing that psi is a measurement of restriction you should see less of it all the while maintaining the same amount of airflow. That's assuming the tune is looking for a specific amount of air flow though.
TXhhr83
2.4L Performance Tech
Jul 10, 2010 01:53 PM
HHRthunder13
2.2L Performance Tech
30
Dec 13, 2009 12:10 PM
Goose
Oct 22, 2007 05:10 PM
