2.2 motor question
Old 04-11-2017, 06:37 AM
hurst2001's Avatar
2.2 motor question
Got a 2007 ls with a 2.2 motor just wondering is this a VVT motor ? I know I don't have exhaust and intake valves sensors so what is this motor consider ?
hurst2001 is offline
Old 04-11-2017, 06:44 AM
It's a good engine! I've got 230,000 miles on mine ! Running fine , I preemptively changed the timing chain and guides and the tensioner, to avoid any problems, it's an Ecotec!
Oldblue is offline
Old 04-11-2017, 06:49 AM
This should explain all about the Ecotec line.
https://en.wikipedia.org/wiki/GM_Ecotec_engine
firemangeorge is offline
Old 04-11-2017, 02:53 PM
hurst2001's Avatar
Well I had the timing chain done at 170000 with a new water pump .. now at 240000 getting no circulation out of it which tends to over heat which I was told by a mechanic I trust so I guess it time for the grave .. it was a gmb pump which I can't see degrade like that in 70000 miles .. oh well the car serve me good for ten years ..
Old 04-11-2017, 02:56 PM
Or change the water pump again , these things happen.
Oldblue is offline
Old 04-11-2017, 04:31 PM
The GMB pumps I've seen were kind of cheap, with a plastic impeller.
donbrew is offline
Old 04-11-2017, 10:15 PM
hurst2001's Avatar
What type pump or brand is better maybe steel ?
Old 04-11-2017, 10:43 PM
I don't remember. You have to look at them. It's one of those things you have to be aware of, I don't think price makes much difference.
If I remember correctly rebuilt pumps seem better to me.
donbrew is offline
Old 04-11-2017, 11:46 PM
hurst2001's Avatar
I seen all kinds of pumps between 45 to 70$ just like to what brand people are using? I won' t use gmb no more
Old 04-12-2017, 08:04 AM
A wide range of new and used pumps
Chevrolet HHR Water Pumps | eBay
Oldblue is offline
Quick Reply: 2.2 motor question
