2.4l Intake Manifold
Old Apr 20, 2013 | 09:28 PM
skyline26's Avatar
bringing this up again, i grabbed a 2.4 mani and tb from a cobalt..im hoping it should fit since prety much same engine..is a tune necessary for the manifold as well or just the tb? I have an 08 hhr, am i going to have the same problem as never2many with the map sensor needing to be moved?
Old Apr 22, 2013 | 06:50 PM
skyline26's Avatar
has nobody else done this swap? is it even worth it?
Old May 3, 2013 | 10:27 AM
skyline26's Avatar
wtf how do you get this damn thing outa the engine bay? there is no friggin room to take it out! help! ive been at this all morning..
Old May 3, 2013 | 10:40 AM
skyline26's Avatar
looks like the fuel rail needs to be taken off
Old May 23, 2013 | 10:22 PM
SwaintaN's Avatar
did you ever get your answer? also while doing this did you swap out to the 2.0tb? little wider then the stock 2.2tb and from what i understand they are same pin pattern.
Old May 24, 2013 | 12:38 PM
  #26
skyline26's Avatar
ended up not doing it, the manifold was a little different
Old May 24, 2013 | 01:23 PM
  #27
prod's Avatar
Just took mine off as part of the sc build, and the gm manual says to take off the fuel rail.
Also I found it helpful to remove the two studs along with the nuts, gives more room to slide the manifold in and out. I dont have the proper external torx socket for the studs, but a standard 7/32 socket worked, they werent in that hard.
The injectors on the other hand, were a b!t&&& to get out. Id try removing the studs first, might get by the fuel rail. And dont forget the brake booster hose by the oil filter.
Old May 24, 2013 | 03:29 PM
  #28
skyline26's Avatar
i ended up snapping the break booster quick connect off the mani lol
but the manifold that i picked up didnt even have that quick connect on it and it was from an 06 ss cobalt..so i gave up
Old May 25, 2013 | 12:23 AM
  #29
prod's Avatar
Cobalt ss has brake booster hose on throttle body, gotta change the hose to reach it.
Old May 25, 2013 | 11:09 AM
  #30
A hint: The 2 top outside bolts need to be pulled out, then you have enough room the rotate and jiggle. The other bolts are captured.
lady3bglover
Oct 26, 2013 10:20 PM
skyline26
2.2L Performance Tech
Oct 19, 2012 07:39 AM
HHRDK
May 6, 2008 07:45 PM
