Cold air intake HELP!
Old May 10, 2014 | 05:58 PM
  #31
Bank 1 lean indicates an air leak. Too much air after the MAF.
Old May 10, 2014 | 06:11 PM
  #32
Britjoe's Avatar
Thanks Ill check in to it.
Old May 11, 2014 | 08:50 PM
  #33
sbrice54's Avatar
Same problem solved
I did a similar intake change yesterday. Got the same code. I checked the inside diameter of the pipe where the maf sensor lives and it was 2.25. I changed from the 2.5 to the 2.25 and it runs great. No lights. No chugging.
Old Jun 24, 2014 | 08:56 PM
  #34
Britjoe's Avatar
Sbrice54, is your cah running with no codes being thrown, now, cause I took mine off, I think its because the Maf sensor tube I have on the the after market induction tube is too large, its 3"
Old Jun 30, 2014 | 05:12 PM
  #35
sbrice54's Avatar
maf sensor
I used the 2.25 inch tube insert.
Old Jul 15, 2014 | 11:10 PM
  #36
Britjoe's Avatar
Reworked Mine got it all working now throughing no codes and Im using a spectre Maf tube
Michael20832
2.0L Performance Tech
Jul 8, 2009 05:16 PM
Geoff
May 30, 2009 08:21 AM
Maroon06
2.4L Performance Tech
11
Oct 22, 2006 07:20 PM
