Heads
Old May 14, 2008 | 06:57 AM
HHRDK's Avatar
Question Heads
Do the 2.2 and 2.4 have the same heads?? If so can we use 2.4 cams?
Old May 14, 2008 | 07:26 AM
hhrcrafty's Avatar
No. 2.4 has variable valve timing.
Old May 14, 2008 | 10:40 AM
HHRDK's Avatar
Hummmm ok what about the bottom ends?
Old May 14, 2008 | 05:40 PM
hhrcrafty's Avatar
Depends on if the engine has individual coils on each plug like the 2.4 (Gen II) or a coil pack and cassette (Gen I). The 2.4 is the Gen II block and only the 2.2 made midyear-07 through 08 uses that block.
Old May 14, 2008 | 08:40 PM
da_dad66's Avatar
switch
can we switch the 2.4 head completely for the 2.2 head like stroker motors do. i have a 07 with individual plug coils. so i fall into that late year 07-08 block
Old May 14, 2008 | 09:56 PM
BigBeefer's Avatar
Not to threadjack too much, but does anybody have a pic of the top end of their 06 2.2? I'm curious as to how the ignition systems differ, appearance wise.
Old May 14, 2008 | 10:23 PM
hhrcrafty's Avatar
Probably. But you're going to have to either switch out some electronics or do some reprogramming and calibration.
Why would you want to lose the VVT anyway?
Old May 30, 2008 | 09:45 PM
sunburstchris's Avatar
well if you end up doing that, ill take your head. (the motor's head that is.)
Old May 30, 2008 | 10:12 PM
ChevyMgr's Avatar
The answer to the OP's question is no. They can not be interchanged.
mitzkity
South Pacific
18
Mar 24, 2010 08:28 AM
dixiesHHR
South Mountain
10
Jul 21, 2007 04:27 PM
TomsHHR
North East
11
Sep 20, 2006 09:24 PM
Krejaton
Apr 7, 2006 05:43 AM
lou
Oct 31, 2005 09:30 AM
