HELP!! Blowing Fuses!!
Old Apr 14, 2019 | 02:46 PM
peanut9479's Avatar
I'm new here, and this is my first post... so bear with me, lol.
Last June (2018) I replaced my fuel pump. No biggie. All has been well until a week ago. This may or may not be related to the fuel pump, but wanted to make sure that you were aware of it. Anyway, about two weeks ago fuse #13 (fuel pump / relay) blew. I replaced it. It was fine for another week, until Friday night (4-12-19). That evening it blew two fuses (#13 under the hood) in a 3 mile stretch of in town driving. Didn't drive it yesterday. Today (4-14-19) it blew 4 fuses to go 3 miles. (I bought a pack of 15amp to keep in the car). What I'm wondering is why?!?! lol. Is their a common place where a wire is known to rub and ground out on this car? I am using the proper 15 Amp fuses.
Any help would be greatly appreciated!
2008 Chevy HHR LT, 2.2, auto trans.
Brad
Old Apr 14, 2019 | 04:21 PM
No typical place. But since you replaced the fuel pump and that is the fuse that blew that narrows it down to the fuel pump wires.
It would help to know what the other fuses are.
Old Apr 14, 2019 | 05:22 PM
peanut9479's Avatar
Same #13 fuse every time.
Old Apr 14, 2019 | 05:28 PM
Then there must be a wire pinched somewhere.
Old Apr 14, 2019 | 05:59 PM
Welcome to the site, yes inspect the wires and connections in the rear by the fuel pump, could be a bent pin, frayed wire, or loose when reconnected after the fuel was reinstalled
https://www.rockauto.com/en/catalog/...onnector,13066
Old Apr 14, 2019 | 07:04 PM
Could the pump be failing(electrically) causing high current draw, blowing the fuse?
Old Apr 14, 2019 | 08:20 PM
Yes, that would be my next suggestion
Old Apr 14, 2019 | 08:33 PM
Radco's Avatar
I agree 110% what was mentioned ! look for a pinched wire ! Please update what you do find
Old Apr 15, 2019 | 07:21 AM
I’m still thinking the same thing , but where?
From the body mounted connections, that vet to the top of the fuel tank.
mojobubba
Aug 30, 2013 03:12 PM
BJarvis
Nov 4, 2011 02:48 PM
SoCalHHR
Sep 5, 2011 12:49 PM
courthousedeb
Jul 10, 2006 01:13 PM
