Info Regaurding Air intakes.
Old Apr 13, 2012 | 08:41 PM
  #31
HHRNole's Avatar
Originally Posted by 08LaRam
I don't know what kind of filter he is actually running but if it is a good one I would bet money it is the BEST performer especially above 45-50 mph! And if he has something to channel the air from that foglight hole (something like a funnel) directly to his air filter that would make it even better.
The whole area in the fender acts as a big airbox.As for the filter I use a Spectre cone filter that is covered with a prefilter. You're right about the performance above 45,its pretty nice for 2.2
Old Apr 13, 2012 | 09:11 PM
  #32
Rod Run's Avatar
And believe it or not pantyhose makes a great prefilter and much cheaper than Outerwear or other brand name prefilters but works great.
Wow, that's a great idea. I've never thought of doing that with any of my cars before that use an open element (that isn't placed where anyone can see it)
Old Apr 14, 2012 | 12:08 AM
  #33
08LaRam's Avatar
The mesh is so fine it usually does not let even fine sand through to an oiled filter. What works better than panty hose is some things they call knee-highs.
Ask your wife or girlfriend what they are if you don't know. You cut them to length from the top and tie a knot in the end you cut. Put the heavy part under the clamp that is used to hold your filter on. Buy black ones then you never have to explain what your prefilter is made from...lol. edit: I forgot to mention turn them wrong side out and make the knot then turn them back right side out and the end looks neat, no knot sticking out lookin trashey. And NO pink.
Old Apr 14, 2012 | 08:30 AM
  #34
HHRNole's Avatar
What? No pink ones?
Old Apr 16, 2012 | 09:09 PM
  #35
swerv0428's Avatar
Just wondering if anyone has a better setup than the stock air hose that runs to the passenger wheel. Mine is kinda screwed up want to get a new one or make my own. Any ideas??
Old Apr 16, 2012 | 09:36 PM
  #36
jay loukakis's Avatar
You can check my profile secveral photos of my modified stock air filter getting cold air from infront of the radiator.
Old Apr 17, 2012 | 12:33 AM
  #37
swerv0428's Avatar
alright so it looks like you made your own extra air intake tube. so you have two of them routed toward the radiator. where are they sitting and how do you have them attached??
Old Apr 17, 2012 | 03:27 AM
  #38
2manyvans's Avatar
I was lucky enough to get this one awhile back! It was modified by Sleeper...Quite a good job if I say so.
Old Apr 17, 2012 | 03:58 PM
  #39
swerv0428's Avatar
Ok so Two more questions. The air tube that runs to the passenger fender, how do you disconnect it from the inside of the fender? Does it just snap in the hole?? And second can that tube be replaced with a different hose such as a metal one or does it need to stay the way it is?
Old Apr 17, 2012 | 05:56 PM
  #40
Yeah, it just fits in that hole. You could replace it with just about whatever you wanted. (that can take the heat) The thing with the stock unit is, that material it's made of catches some larger junk, (leaf bits, bugs, whatever) acting somewhat like a "pre-filter".
