K&n fipk
Mhhmm now this is getting annoying. So externally it could be the same but then K&N does not recognize that they can be both used. I assume it has to do with Product Liability but still....
Took a while to get back to this thread.. The two engines to have a different intake manifold, but this doesn't affect the cold air system. On my '08 2.2, three of the four holes from the K&N box to the valve cover lined up perfectly, the fourth having to be drilled into the bottom of the box. Otherwise, absolutely everything worked perfectly, zero other issues.
