Moving the second O2 sensor, will it cure the P0420 code?
Old Mar 21, 2017 | 07:24 AM
No problem, you're welcome.
Old Apr 13, 2017 | 10:57 AM
And my old dp engine end
Attached Thumbnails Moving the second O2 sensor, will it cure the P0420 code?-img_0428.jpg
Old Apr 13, 2017 | 10:58 AM
Crimped bends
Attached Thumbnails Moving the second O2 sensor, will it cure the P0420 code?-img_0430.jpg
Old Apr 13, 2017 | 10:59 AM
And the rear flange only 1 3/4 inches
Attached Thumbnails Moving the second O2 sensor, will it cure the P0420 code?-img_0431.jpg
Old Feb 24, 2018 | 08:20 AM
One year follow up, the 2nd O2 sensor is still in the spacer, out of the exhaust flow, no P0420 code.
The new catalytic converter bolted in and is performing well, there’s an improvement in throttle response, I believe due to better flow , with the larger diameter pipe and mandrel bends.
Would I recommend this, yes.
Would I do this for a performance gain , could be.
The spacer is not what stopped the code, I believe the new catalytic converter is the reason for that.
Old Jul 19, 2018 | 11:47 AM
  #26
It was the new catalytic converter that cured the P0420, the old one was plugged up from the inability to burn off the oil sucked out of my valve cover.
donbrew
Jun 6, 2020 02:44 PM
NxlKing2304
Feb 14, 2014 07:41 AM
NxlKing2304
Jan 24, 2014 11:34 AM
ZTony8
Nov 3, 2011 09:44 PM
CarlsSS
Oct 4, 2010 10:09 PM
