No cold idle
Old Dec 3, 2024 | 10:30 AM
Tweetip10's Avatar
That’s all of the scans.
Old Dec 3, 2024 | 10:46 AM
Have you been clearing the codes? Every time you do that the OBD testing starts over, the EVAP and cat can take 10 days.
Or, the cat is clogged and causing the problem.
Until the O2sensor tests run the computer is in open loop.
Old Dec 3, 2024 | 10:50 AM
Tweetip10's Avatar
I disconnected the battery before changing the maf and cannon plug. So, yes I guess when the capacitors discharged codes were cleared.
Old Dec 3, 2024 | 11:22 AM
Your temps are in Centigrade. I don’t do conversions well. I’m a Fahrenheit guy. 🤔
Is this one of those Canuck Metric HHR’s ?
Old Dec 3, 2024 | 12:20 PM
Nothing to do with capacitors. Disconnecting the battery reboots the computers, does the same as clearing codes with the reader. Note: don't do it within 10 days getting a smog test.
Old Dec 3, 2024 | 01:27 PM
  #26
Originally Posted by Tweetip10
the ALCH is high , maybe Pulpfiction can elaborate
Old Dec 3, 2024 | 01:45 PM
  #27
Tweetip10's Avatar
Code also was u0100 not p0100. I found the paperwork. This code was produced Sunday after changing throttle body, evap solenoid, and maf sensor and reinstalling old parts after no change in engine. Then it produced codes. After taking battery cable off for 30 minutes all codes cleared but still runs badly. No light or codes now.
Old Dec 3, 2024 | 01:51 PM
  #28
Isn’t 10% normal for ethanol regular gas ?
Old Dec 3, 2024 | 01:54 PM
  #29
Most of our gas in the USA is e10, so that seems right.
U0100 lost communication with ECM. You might disconnect the negative battery terminal, then take off the connectors for the ECM, inspect and clean up the connections.
Old Dec 3, 2024 | 02:46 PM
  #30
And tighten those 4 bolts in the under hood fuse box
Im not sure about the alcohol percentage, pulp has his finger on the pulse of that
