Replacing my engine
Old 10-15-2014, 11:36 AM
Ashcota's Avatar
Replacing my engine
Hey guys just joking the site. I have found lots of great info on some minor issues but now I have a blown motor. I have a 2.2 2006 hhr. My question is can I use other motors from GM? For instance Malibu or colbalt or Saturn. Any info is great guys thanks in advance
Ashcota is offline
Old 10-15-2014, 12:26 PM
LawDog88 - Please, that is totally misleading.
whopper is offline
Old 10-15-2014, 12:51 PM
Ashcota's Avatar
replacing my engine
well i have located a few for around $750 with 88k miles on them. now i am deciding if i should do it my self or have it put in.
Ashcota is offline
Old 10-15-2014, 01:29 PM
07azhhr's Avatar
If you have an 06 then you have a slightly different motor than any other year 2.2L. For an easy and direct swap your motor needs to come from another 06 GM car. this is because they use different ignition parts including a different reluctor wheel and crank sensor. The reluctor wheel is not serviceable without removing the crank.
In another thread it was questioned if one could use a newer motor if you also used it's harness and engine computer. Since non standard motor swaps are done that way I do not see why that would not be possible. But the work involved is not simple.
Either of these options as you can see will add a lot more work. This will also increase costs. So again be sure the motor is from an 06 and you will be good to go.
07azhhr is offline
Old 10-15-2014, 01:47 PM
Ashcota's Avatar
i found a 06 hhr motor for 550 with 70k on it its a match to what i have. i plan on doing it my self. any tips or sugestions for me? i have read a few differnt ways to take out the motor. which is the best?
Ashcota is offline
Old 10-15-2014, 03:42 PM
All of the mechanics I talk to say dropping it out the bottom is easiest. But then they have a lift.
donbrew is offline
Old 10-15-2014, 04:09 PM
victweezy's Avatar
Just put a junkyard engine in my 06 that is a modge podge of a Cavalier, ION and Malibu. I'm praying she will work and I won't have to go pull the ignition stuff from the ION that the crank and block came from.
victweezy is offline
Old 10-15-2014, 08:32 PM
Ashcota's Avatar
I might try to drop it from the bottom. Just bought the Haynes manual to get this party started
Ashcota is offline
Old 10-15-2014, 08:53 PM
Where in Wa. This might be fun to watch....
SS fan is offline
Old 10-15-2014, 09:39 PM
Grizzly old man's Avatar
Here is my thread on engine swapping
https://www.chevyhhr.net/forums/prob...e-50425/page2/
The '06 really is a different animal than the rest of the HHR's you might be lucky to find an engine from a Saturn that will fit and I think also a G6 but its gotta be an '06, that's why I went with SW Engines. I got the 2 year warrantee so my total cost was like $1315.00 which included shipping. The shop I hired to do the job charged me around a grand to put it in.
I lack the equipment to do full engine swaps these days so I had to hire it done.
Grizzly old man is offline
Quick Reply: Replacing my engine
