Single Cylinder Misfire - intake valve spring
You know you can put more than one pic in a post? Just drag and drop as many as you like onto the form. If you are going to be posting more than 1 or 2 pix you should resize them for the sake of those using cell phones.
It's an automatic, what difference does P or N make?
You might want to just start a new thread in the How-To library with your procedure.
I think 1 is at TDC. Intake and exhaust valves of 1 are closed. 1 and 4 are both at the top while 2 and 3 are at the bottom. 2's intake valves are closed. 2's exhaust valves are going to be opened or already opened a little bit. 3's intake valves are going to be closed. 3's exhaust valves are closed. 4's intake valves are going to be opened or already opened a little bit. 4's exhaust are going to be closed.
If they are still open, even a little, after BDC, the air-fuel mixture gets pushed back into the intake manifold.
You may want to verify that the timing is correct, it may be a tooth off.
So that means #1 intake is open at BDC also, when #3 is at TDC.
This supports the theory that the #3 intake valve(s) are burnt or otherwise not sealing.
And the oil didn't help much this time, suggesting maybe the problem is not the rings.
