Stroker build
Old Apr 24, 2026 | 05:06 PM
Handsumrob28*'s Avatar
Stroker build
OK having a 2.2 L engine and you’re putting a 2.4 L crankshaft in it the issue isn’t the counterweight hitting the piston is the reluctor wheel for your crankshaft which really you just need one piston on that back number four cylinder but you also need the 82172.4 L crankshaft rods your original Pistons will work except the number forth one but you can grind it down yourself to make it have clearance
Old Apr 25, 2026 | 10:08 AM
Is that crank shaft rod , the connecting rod part # or casting #
bigallis1
May 11, 2007 03:42 AM
Mr.Gar
Apr 16, 2007 01:48 PM
karen1953
Mar 22, 2007 12:57 PM
O6ChevyHHR
Jul 19, 2006 12:21 PM
EZ4U2CHere
Jul 5, 2006 10:02 PM
