2.4l to 2.2l Swap
Old Aug 18, 2016 | 04:49 PM
repairguy311's Avatar
Originally Posted by Jimmy68
Must have a big hole in the block.
Bingo. Surprisingly it still runs, it is just noisy and making an oil mess.
Old Aug 18, 2016 | 04:54 PM
Originally Posted by donbrew
The electronics are different between a 2.2L and a 2.4L, the harnesses are different, the 2006 has an entirely different ECM. The ECM has to agree with the BCM.
I am not sure, but it would probably be easiest to take the ECM, BCM, TCM, engine harness, ignition theft module from the donor. And then I don't know how the Restraint computers or the ABS and traction control computers would work, since they interact with the BCM and ECM.
The GM LAN and CAN BUS are probably different.
You may have trouble with the DMV, and insurance company.
Cheaper to get a matching used engine. But, you seem to be up for a challenge.
Every car I've had since 1970 has had a PRDIL, made famous on "Green Acres". Sometimes marked PRD2L. The operation of the "I" is covered in the Owner Manual, available through the link in my sig.
Only your first post was moderated, that might be because you didn't reply to an email from the admin to complete registration. On this site you have to refresh the page and sometimes back up and re load the page to see your new post.
All of the posts I have made except the very first one are not visible to me, and I still get the page saying my post must be aproved by an admin. It is my understanding the 2.2l harness and the 2.4l harness are identical except for the 3 additional connectors used for the vvt on the 2.4. I wouldnt think the sensors are different even though the years changed. I understand the gmlan and can bus difference, but that is the method the modules talk to each other, not the modules to the sensors. Is there anything different between an 06 2.2 and 09 2.2?
Old Aug 18, 2016 | 04:57 PM
Originally Posted by solman98
In your case, will probably be easier to put the V8 in the 06.
That definitely would be easier, but the 06 is my wife's car, and she is very partial to it.
Old Aug 18, 2016 | 05:04 PM
Literally every chevrolet or chevy affiliated product i have ever owned until that saturn was PRND2L, PRND21, PRND321 or PRND32L.
Old Jan 1, 2018 | 11:49 PM
Hadn't thought about this in a while and wanted to update everyone. The 2.2l from the 2009 is a vvt engine just like the 2006 2.4l. The engine bolted up fine. To avoid problems with computers talking to each other, I used the engine harness from the 2006. The intake on the 2.2l was cracked so I used the intake from the 2.4l. The 2.2l was a flex fuel engine and I was worried the injectors flows would be off so I got injectors from a early cobalt 2.2l at the local u pull it. The exhaust manifold was cracked on both of them, so I purchased a new exhaust manifold for the 2.4l and bolted it to the 2.2l. I used the 2.4l cat converter setup. The swap worked fine. The car runs and drives fine and I have put 10k plus miles on it since the swap and no issues.
Old Jan 3, 2018 | 08:04 AM
Awesome, thanks for the update!
John Lennon was right, there’s nothing you can do, that can’t be done.
Enjoy the ride!
Old Jan 3, 2018 | 08:49 AM
I fixed the unapproved posts. I don't know what that was about.
Old Jan 3, 2018 | 11:54 PM
SuKi's Avatar
I'm glad to hear your wife's car is running well, but what about your project? Any plans or work started on the V8 2009?
Old Jan 5, 2018 | 05:51 PM
Unfortunately, The company I was working for closed and I lost the fringe benefit of a huge climate controlled shop. I have a new job. I am working on building a garage for myself, I really dont want to take on a project like that without at least a roof over it. I did buy a wrecked pickup with a 6.0l lq4 and a 2wd 4l80, so I have a donor, just need some space.
Old Sep 9, 2018 | 01:49 PM
HHR454guy's Avatar
Wow, sounds like real interesting swap. Please keep us updated when your garage is built.
tsaints1115
Dec 12, 2007 01:34 PM
Airborne_Beachbum
2.4L Performance Tech
13
Dec 25, 2006 08:21 AM
