dynos done today
Old Apr 25, 2008 | 08:23 PM
furious's Avatar
i can't see the image
Old Apr 25, 2008 | 09:26 PM
TomsHHR's Avatar
93 octane...
Old Apr 26, 2008 | 09:49 AM
JoeR's Avatar
Triple Turbonators?
Quad eRAMs?
Photoshop job?
Bet it's "bottle"!
A few comments, though...
That better pull sure takes a dump in the mid-range! And the dyno curves don't look right, likely not calibrated right. On each, the HP and TQ curves should cross at 5,250 RPM. The lower one crosses a little low and the upper one is WAY off.
Finally, on both the AFR curves stay near stoic through the mid-range. Not good for power and could be dangerous (too lean) with spray (or whatever the "secret" is). Matt at Tune Time has a good reputation, but you should really contact him to get rid of the PE delay and work the tables.
Old Apr 28, 2008 | 11:41 AM
A 50 shot of nitrous with my new ZEX set-up did the trick!
Had a whole bunch of fun using up the 10 lb. tank this weekend.
PUR Performance in St. Charles did the work and the dynos.
They did say it was running a little lean and I'll be calling Matt @ Tune Time real soon to see what he has to say.
Old Apr 28, 2008 | 12:11 PM
Big Kahuna's Avatar
SWEET!!!
So, ya got the bottle hooked up... You'll have to post some pictures of the final setup. Last time I saw the set up with the empty bottle was an incredibly cool layout in the back!
Let me know when you'll be doing some runs out a Gateway International...
Old Apr 28, 2008 | 04:59 PM
It is a BLAST to drive! Not that it wasn't before, but the difference at WOT is amazing!!
Old Apr 28, 2008 | 05:03 PM
Originally Posted by Graunkem
What kind of "Custom" exhaust? Cat back? Full system with a header?
Took everything off from behind the cat.
Where the resonator was now rests a 24" Thrush; a Y pipe off off that which leads to a small Walker resonator on each side ending with a dual tip on each side.
Old Apr 28, 2008 | 06:34 PM
RUDEINC's Avatar
Mike, good to see you got it setup. Regards
Old Apr 28, 2008 | 08:40 PM
Thanks Mark, mine's a little more tucked away under the hood than yours. Your's was the inspiration for mine.
Went with a remote botte opener. Someone talked me outa using a bottle warmer and now I wish I hadn't. Friday 70 degrees out, pressure gauge read 8; next day, 50 degrees out, pressure gauge read 6. Thinkin of going ahead and adding one.
Old Apr 28, 2008 | 08:50 PM
RUDEINC's Avatar
Yeah, the warmer is absolutely needed to maintain consistent bottle pressure which is so important. I thought I told you about that in our PM..lol... ...BTW...What plugs did you end up installing? I think that I'm going to try out the NGK's this year, I wasn't real impressed with the ZEX plugs when it came down to everyday driving. Well congrats, and post some underhood pics if you get a chance...Regards...Mark
