Has anyone installed Headers on a HHR
Old Jun 7, 2007 | 02:01 PM
hnewagn's Avatar
I was thinking of geting a header and hoping that someone could point me in the right direction I was looking at this one http://www.shiny-hiney.com/header.html if any one has a header let me know.
God Bless!
Rick Johnson
Old Jun 7, 2007 | 07:49 PM
Applenut's Avatar
I have that header, and the coolant line on the 2.4 is in the way, haven't looked at how to turn the line to make it work, but a member here, hvrod, has this one installed and working fine!
Old Jun 7, 2007 | 10:01 PM
JoeR's Avatar
That looks like the same header from Cobalt Addiction.
Like many "claimed" gains, don't expect much.
As for the coolant pipe that crosses on the back side of the block, if that is a problem, there is an O-ring connection at each end. A strong grip and it can be rotated some.
Actually in dyno tests with another manufacturer, the factory manifold is not that bad at all, a much better design that manifolds of old!
GM has what is called an "extrude honed" manifold available, where they pump an abrasive putty-like substance through it to smooth and enlarge the passages.
The 2.4 exhaust system is pretty well designed from the factory and difficult to improve upon. The much heralded IMCO muffler is actually more restrictive than the stock muffler, which will result in a slight, but hard to notice, power loss. It may offer a "better" sound to some, but sound does not = HP.
Without going into serious internal engine mods, your best "bang for the buck" would be a good ECM tune.
Old Jun 9, 2007 | 12:17 AM
flyhhr's Avatar
hi have the header from vibrant on my hhr and I love it.
for the cali people you mite not be able to use it hi flow cat
Old Jun 9, 2007 | 11:09 AM
hvrod's Avatar
God Bless!
Rick Johnson
I used Cobalt-additions Header and High flow cat...
Old Jun 9, 2007 | 04:00 PM
hnewagn's Avatar
Can you post a link or part number.
Thanks
Old Jun 9, 2007 | 05:39 PM
RUDEINC's Avatar
Thanks
http://www.cobalt-addiction.com/performance.htm
Old Jun 13, 2007 | 09:48 PM
ssfamilywagon's Avatar
Hello. Just wanted to add. I have the Cobalt Addiction header and down pipe. I think they're great pieces and bolted right up. No prob. I noticed a good gain from them. But as a suggestion. If you start to mod the intake and exhaust, you will start to lean out on the top end. I would suggest a tune and SS/SC Injectors. When we tuned my car, we noticed that with an intake and muffler, it had slight knock n injector duty cycle was high.
Just some info.
black Tara
Dec 22, 2014 08:31 PM
DANSHHR
2.2L Performance Tech
Jan 20, 2014 05:17 PM
American & Proud
2.4L Performance Tech
10
Sep 9, 2012 07:24 PM
sirrocket1975
26
Mar 3, 2008 07:53 AM
