Lighter pullies installed -md- HHR this is for you
Old Jun 15, 2007 | 07:38 PM
  #71
Applenut's Avatar
This is the kind of "bolt-on" performance a lot of us are looking for.
One question though, if I already have my car tuned by Tune-Tyme, would they need to re-tune after installation??
Old Jun 16, 2007 | 01:04 AM
  #72
upOnGamE's Avatar
no, your not really letiing it breath or adding more a/f so you should be just fine
Old Jun 16, 2007 | 02:19 AM
  #73
ssfamilywagon's Avatar
well i just got finished installing my stock size lightened crank pulley. you can def tell a difference. with no load, the motor does rev quicker. my buddy and i both did a before and after drive n could tell n improvement. now i just need to compliment it with the alt. pulley.
Old Jun 16, 2007 | 07:21 AM
  #74
Applenut's Avatar
Yeah.....I need these......
Old Jun 16, 2007 | 09:05 AM
  #75
Tennpenn83's Avatar
late night there, ssfamilywagon? lol, i remember those nights!
my input on the issue at hand, for the record, ANY weight you take off the engine will make it free up horsepower. 3-4 pounds less of a crank pulley may be sitting still, but what is that 3-4 pounds at higher rpms?
simple example, why do people get lighter wheels/tires? apart from probably being stronger than stock ones, they take off a tremendous amount of
rotational mass. less rotational mass means less load on the engine. less load on the engine means freed up horsepower
another example? take off your a/c compressor and get another belt to compensate for not having one. no a/c compressor = less parts to move = less rotational mass = freeing up more horsepower
Like enOonmaI said, magazines have been proving it for years. look it up instead of doubting it just to doubt it
Old Jun 16, 2007 | 01:53 PM
  #76
Lee3333's Avatar
Hi-especially SSFamily Wagon:
How hard was it to get the old pulley off and new one on? Did you need a lift? Where did you get it? I want desparatly to be the next one here to do the pulleys
Old Jun 16, 2007 | 01:59 PM
  #77
upOnGamE's Avatar
i got the pullies,intake (which i listen to nobull about getting airaid not cgs) short shifter, axel back dual exhaust and thats it but please guys remeber there is so much more you can do..header/down pipe/ upgrade your injectors with the proper tune/ port and polish your heads/ you can upgrade your springs/retainers and raise your red line.........these little engines can
Old Jun 18, 2007 | 08:32 AM
  #78
-md- HHR's Avatar
56K aaaaaahahahah
Originally Posted by en0oNmAI
Either way. Md was right, as were us "youngins" and MD was able to PROVE this. Way to go MD for an outstanding product.
Now there's only one question left. Where can I find these wonderful pulleys MD???? If need be PM me any info. And thanks again! :twothumbs
I'm not in the production stage yet. Just prototypes. I'm having 50-75 alternator pulleys made soon...when I do I'll probably sell them on ebay and j-body.org, and become a supporting vendor here. But I only have a few prototypes as of right now.
Heres some pics from my last group purchase on j-body.
Old Jun 18, 2007 | 08:33 PM
  #79
actually it was really easy to change the pulley. i didn't use a lift at all. you just need a floor jack and jack stand. on my car i had to remove the intake to give me room to swing the tool for the belt ten. just removed my pass front tire and loosened the front portion of my wheel well. one bolt holds the pulley on. used my impact for that, and then you could just literally pull it off wit your hands.
Old Jun 19, 2007 | 06:20 AM
  #80
-md- HHR's Avatar
Most crank pulleys will require a pulley puller...it shouldn't just slide off "that" easy.
