missing thrush washer or shim
Old Jan 6, 2023 | 01:50 PM
martyb's Avatar
Originally Posted by Oldblue
I’m not seeing any shims for the 2.4 or the 2.2 in 2007, I’ve done several timing chain replacements on these and don’t recall seeing a shim or washer in any of them.
is it possible someone replaced the OEM harmonic balancer with a 2.0 balancer? There are shims for those.
I don't believe so when we tore it down it was behind the sprocket! The thin washers are really flimsy and the one we pulled out was more like the one on the balancer bolt, made out of stamped steel like the flimsy ones. The VIN 3GNDA33P57S594569 MAKES IT A 2.4 Thanks.
Old Jan 6, 2023 | 03:01 PM
I’ve got a 2.4, no shims or washers
Old Jan 6, 2023 | 04:57 PM
is that a parts schematic of an LNF or LE5?
This was LNF. The diagrams for the other engines seem to be missing. I didn't go looking too hard.
EDIT: I found the diagrams for 2.2 and for 2.4 - no shims.
But let's think about it. Maybe the shims are pushing the cover out a little? Try without the shims. If it still isn't right, try a new balancer.
Old Jan 6, 2023 | 05:56 PM
The shims would move the balancer not the cover.
Old Jan 6, 2023 | 06:43 PM
Must be the wrong balancer then. The thick washer was compensating for it? I think there would be a point where a washer that was too thick would interfere with the front seal, right?
Here's the 2.4
Old Jan 6, 2023 | 06:52 PM
Engine Crankshaft Pulley
Part Number: 90537704
Supersession(s): 90537704; 12787628; 12623793; 55355289
Old Jan 6, 2023 | 09:11 PM
martyb's Avatar
All I can is without it the balancer rubs the timing cover, we try a new balancer same thing it rubs.
Old Jan 6, 2023 | 09:27 PM
I would guess either the timing cover is bent/deformed or it is not pulling down flush when you snug up the bolts.
Any chance that someone replaced the timing cover gasket but forgot to remove the old gasket ?
2 gaskets would cause the timing cover to stick out too far. Then the balancer would possibly rub on the cover.
Old Jan 7, 2023 | 07:08 AM
That has happened before, here on the site a few years ago.
Old Jan 7, 2023 | 11:19 AM
hhrumadbruh's Avatar
Seems like a hard one to miss lol
