My 2006 2.4 TURBO HHR!
Old Dec 30, 2010 | 03:13 PM
  #71
ChevyMgr's Avatar
If you want to make posts concerning what an HHR auto transmission can take or not take. Create a new thread. This thread is about Mikes HHR. Thanks.
Old Jan 3, 2011 | 08:05 AM
  #72
mrarff's Avatar
Mr Manager, Sir, Previous comments made were concerning the ability of the HHR auto tranny to handle power. I felt my comment WAS NOT off-topic. And I stand by my comment.
Old Feb 2, 2011 | 12:20 PM
  #73
EnglishRacing's Avatar
Cool 2.4L turbo HHR
I just purchased a 07 HHR 2.4L ,15000 milies ,And I plan to turbo it this summer using an AEROCHARGER , very easy installation considering you dont need a turbo timer nor run any oil lines. But wanted to know if you guys know what exaust manifold to use (T3T4) and down pipe? from the cobolt perhaps or a solstice 2.4. Will i need to do anything with the computer or fuel delivery,plan on running 10psi.- BiG GarY
EnglishRacing@Yahoo.com
Old Feb 2, 2011 | 03:16 PM
  #74
I would think that you'll need to tune, and need larger injectors.
Old Feb 4, 2011 | 09:43 PM
  #75
hhrfreek's Avatar
Not sure what header/dp you will need b/c I have a SC 2.4, but you will need injectors and a tune as GDZHHR said. As for compatibility I know Cobalt exhaust parts are. I am at 11psi and I needed to get 60lb injectors(Siemens). My stage 1 kit came with 39lb injectors and they were maxed at 7psi, so don't bother with those. The 60's will allow you to run 15psi if you have supporting mods to do so. At max my injector duty cycle is 68%. The connection type is EV6. The LSJ/EV1 type will not work. Your tune is very important. Don't even bother starting the car because it will likely not run and if it does that doesn't mean you should drive it. You will blow it up the first time you floor it. Many reputable tuners will be able to build a good tune for you.
Old Feb 12, 2011 | 11:49 PM
  #76
i have a 2007 HHR,2.4L . My complaint is with the traction control, it is only disarmed in low 1. how can i get the traction control off in all gearsmotherwise when 300hp spin the wheels in second gearmthe tc suts down the accelerator pedal and engine goes to idel until wheels grip evenly. help EnglishRacing@yahoo.com
Old Feb 12, 2011 | 11:50 PM
  #77
pardon the mispeeld werds
Old Feb 13, 2011 | 08:07 AM
  #78
I'm having the same issue, if you find a solution let me know
Old Feb 13, 2011 | 09:45 AM
  #79
Gotta be a way to replicate the switch that's on the E-brake and install it on the dash..... I haven't looked into this yet, but it seems feasible.....
Old Feb 14, 2011 | 12:38 AM
  #80
PhoS's Avatar
I had my traction control eliminated with my ECM tune.
