P0121 code
Old May 29, 2017 | 11:00 AM
The problem with mounting a turbo on the 2.4 non turbo engine is predominantly the HPFP is non existent, so the turbo spins, forcing extra air into the intake, but the electric pump in the tank can't keep up! So, you get a lean fuel load!
Did the turbo setup come with fuel injectors designed to work with the turbo?
A fuel pump with more volume to mount in the tank?
What about the throttle body, from a 2.0 turbo or did you reuse the stock 2.4 TB ?
I think y'all see where this is going!
Old May 29, 2017 | 11:52 AM
cllwyrc1's Avatar
Yes came with injectors. Everything was used that came from the dinar car and he didn't have any problems. I changed to different injectors cause that's what the previous tuner recommended that I changed to. Stock throttle body. The lean and rich condition have gone away just can't figure out the 121.
PanamaJack
Jul 11, 2016 10:14 AM
britishknigth
Jan 31, 2015 07:28 PM
NxlKing2304
Feb 14, 2014 07:41 AM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
