Random cylinder 4 misfire
Old Aug 11, 2024 | 09:15 PM
  #41
Low compression in one cylinder call for a leak-down test.
This is correct. You don't want to put a new head on it if it has a hole in the piston or bad rings.
What Greg said is good too. Pretty easy to pull the valve cover and look at the valve springs.
Old Aug 12, 2024 | 06:14 AM
  #42
HB2's Avatar
HB2
No air or water where it shouldn't be. And, how could a bent valve or broken valve spring not miss until the engine warms up, quit when it cools off, then miss again??? TCL is my abbreviation for Traction Control Light. And do you think it would be running as good as it does WITH A HOLE IN A PISTON? Come on RS SS, give me a little credit.
Old Aug 12, 2024 | 08:10 AM
  #43
250 was just a typo by Oldblue. He’s very well aware of what the cylinder pressures should be.
Old Aug 12, 2024 | 08:18 AM
  #44
Thanks FMG , I corrected that typo.
leak down test , doesn’t work well for a burnt exhaust valve , let’s not forget these engines have two exhaust and two intake valves per cylinder. A visual inspection is always best!
Old Aug 12, 2024 | 08:21 AM
  #45
Because the computer is in open loop mode until it warms up.
If coolant is not disappearing it is unlikely to be a head gasket. You are throwing your money around if you don't do a leakdown and maybe a scope to actually look at the cylinder.
Jfidelh
Mar 26, 2023 04:27 PM
Lee3333
Jan 16, 2016 06:13 PM
ptolene
Dec 18, 2014 09:00 AM
dzmija
Oct 27, 2013 04:34 PM
ATLsilverSS
11
Aug 8, 2010 03:37 PM
