Rpms?
Old Jul 1, 2017 | 07:27 AM
The MAF is that bit that you must unplug to get the air cleaner off. Either it is not plugged in correctly, a wire is broken or it is broken.
Old Jul 1, 2017 | 07:32 AM
aradmahogany's Avatar
and that would not only effect idle but most likely the rpms it runs at speed correct?
Old Jul 1, 2017 | 09:12 AM
Correct, and it usually sets a CEL
Old Jul 2, 2017 | 09:55 PM
BethnPete's Avatar
Thanks for the info, everyone
Thanks for the help, I will check it out
Could a separation in the air intake hose cause a problem? Just discovered this
Old Jul 2, 2017 | 10:56 PM
If you mean the fuzzy pipe that goes to the fender; no.
If you mean the rubber pipe that goes to the carb; yes
Old Jul 3, 2017 | 12:35 PM
BethnPete's Avatar
It is the one that goes to the fender...TG
Old Jul 3, 2017 | 04:00 PM
The cold air intake tube you speak of , commonly called the woolly worm, is abut expensive but can be replaced by a 3 inch diameter piece of dryer hose, the metal style like this
Old Feb 6, 2018 | 04:45 PM
UltraviolentDroog's Avatar
Originally Posted by BethnPete
Just curious...what RPM should a 2008 2.4L be running at 55-60?
I just posted something similar.
My 5speed is at 70mph at 3000rpm. 5th gear
Old Feb 7, 2018 | 09:32 AM
Cat Man HHR's Avatar
I can drive it at 55-60 running at 2500-3000 RPM
Your stuck in 3rd gear if it's an automatic.
4th would be 2000 rpm at 60 mph using 215/50R17 tires
Arly08
Fuel Economy - Hypermiling
14
Apr 24, 2009 09:43 AM
WickedHHRLT
Jan 24, 2007 11:29 PM
longhorn
Nov 5, 2006 09:53 PM
