Supercharged HHR
Old Jul 29, 2016 | 11:02 AM
  #151
hhrfreek's Avatar
Right. I am wondering why you didn't just get an EV6 42lb injector to work with the stock harness?
Old Jul 29, 2016 | 05:49 PM
  #152
thehappyfrog's Avatar
Hi folks, good ideas I'll try out a new injector harness. We are going to check out the sensors and backprobe them first to make sure everything is working alright. So far we have done a voltage drop test and the harness itself is getting power where it needs to go, and the grounds all check out.
As for the #60 injectors that we are using, I'm just using everything that came with this kit from ZZP:
Ecotec Parts 2.2/2.4L Bolt on Supercharger Kit
It didn't mention or come with any new injector harness, and said everything would work with stock 2.4lt ecotec, so that's what we went with so far. Essentially this kit is for a 2007 cobalt SS which is similar to the 2007 hhr, although I have found some differences with the help of people on this forum.
So after checking that link, do you think I would need a new harness?
From the website:
http://zzperformance.com/ecotec/siem...jectors-4.html
How can i know which injector model is the right one for my car?
The only ones that drop in without our Ecotec Injector Harness are the EV6 ones and they only directly drop in a 2.4L LE5 car.
My 2007 HHR is 2.4L, so I feel the harness is ok. I'll check it regardless. The kit comes with EV6 injectors.
Old Jul 29, 2016 | 11:29 PM
  #153
RF2's Avatar
RF2
pics of stock injector connector and one like I used.
Attached Thumbnails Supercharged HHR-img_0735.jpg   Supercharged HHR-img_0736.jpg
Old Jul 30, 2016 | 11:29 AM
  #154
hhrfreek's Avatar
If you use EV6 long style injectors you are fine. That is what you get in the ZZP kit. They work with stock harness and rail. You should not have an issue.
Old Aug 1, 2016 | 04:42 PM
  #155
Thanks brother!
Old Aug 1, 2016 | 04:44 PM
  #156
FINALLY found our issue (a 3-parter, I'll post more when it's all good), but once we got the engine running the belt from the ZZP kit split and tore a rib off. It may not have been on properly from the last mechanic, but hhrfreek do you know if the belt from the ZZP kit is the proper number of ribs for an HHR?
Thanks!
Old Aug 2, 2016 | 06:38 AM
  #157
hhrfreek's Avatar
Yes the pulleys are the same on a Cobalt and HHR.
Old Aug 10, 2016 | 08:54 PM
  #158
Hmmm, still having issues. Only code now is a P0107. Even if MAP sensor is unplugged, the car should start but it will only crank for me. Did you have to use a fuel pressure regulator or anything like that? Gonna backprobe the MAP tomorrow.
Old Aug 10, 2016 | 09:24 PM
  #159
The MAP sensor is sending less than .25 volts, which means it is either defective or not getting the 5V ref.. It is supposed to send between about 1V and about 4.5V to the ECM through a variable resistor.
The sensor is pretty simple; exactly 5V into the resistor and 1V-4.5V out. Wire is broken somewhere if the Throttle still works, it uses both 5V references, so if either was bad it would not work and you would have a CEL p0651 (I think).
http://www.obd-codes.com/p0107
Old Aug 11, 2016 | 06:05 AM
  #160
hhrfreek's Avatar
Nope. I used stock fuel system with larger injectors.
IIRC the injector harness and throttle body use the same connector. Make sure they are not crossed. I think you'd get a variety of codes for that though.
What map are you using? If using the 2.5bar see thread below to double check your work with the diagram in the first post.
HELP NEEDED: Wiring TMAP/MAF Temp Reading for 2007 2.2L Supercharger Build - Saturn ION RedLine Forums
