Disassembled Headlight
Old Aug 7, 2008 | 07:18 PM
1Panel2NV's Avatar
I've seen pictures of a Cobalt headlight but never an HHR, so hear it is. It's three main pieces like on Cobalts, but the turn signal is a little different. The amber piece is flat and fits over the chrome turn signal housing.
Old Aug 7, 2008 | 09:16 PM
SLVR FOX's Avatar
was that hard to do?
Old Aug 7, 2008 | 09:17 PM
jeffs396's Avatar
Now what are you going to do with it to make it cool???
Old Aug 7, 2008 | 09:59 PM
1Panel2NV's Avatar
It wasn't really hard, but is was time consuming. I still have to open the other one up and mask it. Then sand, primer, and paint both.
Chrome will be black, tape will be chrome, no amber, and finish off with silverstar turn signal lamps.
Old Aug 7, 2008 | 10:00 PM
Inquiring minds want to know..............
Old Aug 7, 2008 | 10:01 PM
Did you bake it?
Old Aug 7, 2008 | 10:08 PM
JACK-07's Avatar
the black paint that you will be using... is it any special style of paint as not to melt from the heat of the bulb? i have been thinking about doing the black style outline setup for a while, just too chicken
Old Aug 7, 2008 | 10:09 PM
1Panel2NV's Avatar
Yep. Tried 200 degrees for about 15 minutes. Nothing. 250 for about 30 minutes finally starting breaking it loose. Then I just started prying around the headlight, reheating, prying, etc. The sealant is like rubber when its cold, but evidently starts melting around 200-250.
It's just gloss black automotive paint that I'm using with a plastic adhesion promoter/primer. Shouldn't be any heat issues since none of the painted area will be hit directly by the bulb.
Old Aug 7, 2008 | 11:41 PM
jeffs396's Avatar
Kendall, I'll bet the parts you're going to do in gloss black would look good in body color...just a thought!
Old Aug 8, 2008 | 12:00 AM
xzombiex66's Avatar
i kinda figured that amber piece was removable, i want to do this so bad. did you really have to remove the front bumper? or did you buy a spare set?
