Disassembled Headlight
Old Aug 8, 2008 | 06:59 AM
Dirtsurfer's Avatar
Is the amber lens going to be reused or replaced by a clear one? With it apart, would it be possible to epoxy a flat lens to the turnsignal housing or is it neccesary to even use it?
Old Aug 8, 2008 | 08:47 AM
stick's Avatar
Originally Posted by chadpuska
i kinda figured that amber piece was removable, i want to do this so bad. did you really have to remove the front bumper? or did you buy a spare set?
I agree with the removal of the amber piece. However, I would have to buy another set to tear apart and then change out.
Old Aug 8, 2008 | 05:39 PM
1Panel2NV's Avatar
They're an extra set I got off ebay. I don't have enough time to do it in one shot. Hopefully I can paint them tomorrow and install on Sunday. About 99% sure the front bumper will need to be removed, due to the design of the headlight.
Body color could look good, but my tail lights and parking lights are tinted already.
Old Aug 11, 2008 | 08:53 PM
1Panel2NV's Avatar
ehhh...slow progress. I had to change things a bit. Here is what I have so far.
Just mocked up
Old Aug 11, 2008 | 09:05 PM
stick's Avatar
What are you going to use to reglue them together?
Old Aug 11, 2008 | 09:30 PM
1Panel2NV's Avatar
I forgot what it's called. I need to make sure it's not silicone based though because a few people mentioned in the cobalt how to that the sealant will eventually cause fogging. And also not letting the paint fully cure can cause fogging. So I'm not putting them back together until the weekend to be safe.
Did you get a magnaflow catback?
Old Aug 11, 2008 | 09:39 PM
stick's Avatar
No, just the muffler. Single, but I like it!
Old Aug 12, 2008 | 06:46 AM
Dirtsurfer's Avatar
When finished, would you take before and after headlight beam pictures? Would be interested to know if the beam changes because of the loss of chrome.
Old Aug 12, 2008 | 07:05 AM
oneton's Avatar
You do not have to take the bumper off, The inner fender panel just needs to be pulled back.
Old Aug 12, 2008 | 11:04 AM
1Panel2NV's Avatar
I'll try and take plenty of pictures. I might make a how-to depending on how things go.
To take the whole headlight out? There's barely enough room to change the bulbs. I think it would be easier to take the bumper off.
