Fogs
Fogs
i dont really want to go aftermarket with fog lights so i dont have to make something fit..so im wondering is there an oem kit that you can get with lights, wiring, fuse, relay or whatever is needed all in one happy kit?
Would dealer have a "kit" or is it just the fog lights then gota buy wiring etc.
Howdy skyline26
Here is the thread i used to install mine,I was very well written.I had to install the lights and the switch into the waterfall.
https://www.chevyhhr.net/forums/how-tutorial-library-21/do-yourself-factory-fogs-637/
Hope this helps,
Doug
Hope this helps,
Doug
I bought a set off ebay that came with everything needed to install them very easy to do. The wire harness that came with them was a little short or i routed it different then they do. But it was like 120 or so. I can post pics if you like.
http://item.mobileweb.ebay.com/viewi...id=23198420486
That is the kit I bought. Comes with everything. I think I sa w in the do it yourself fog thread how to wire them in like factory. I will take pictures in a little bit of mine
I have an LT that did not come with Fog lamps, but I have been intending on adding them. I purchased a waterfall that had the fog lamp switch in it, and the harness is already behind the dash. I connected the harness and as far as I know the switch works perfectly. now i havent looked to see if the fog light harnesses are there behind the bumper or not, but I am assuming that they are. Technically all i think that I need is the bulbs/housing and they should work. Not sure if anyone else has done this.
