Lumen replacement LED bulbs
Unfortunately LED Hi/low beam bulbs are not available in dual beam version H13 that is required for HHR (with high and low beam in one bulb). Not sure if they exist yet, but I am pretty sure they will be available on the market soon.
However if you would like to get brighter High/low beams - Silvania will do it for you. They provide much better brightness in compare with stock halogen lights. They also have lower glare level, which makes them less blinding than HID.
There is H13 dual bulb (with both high and low inside). SylvaniaŽ - Chevy HHR 2009 Headlight Replacement Bulbs
Doesn't Sylvania have a big recall on their "brighter" bulbs. I think I posted a thread regarding that.
Besides, with all do respect to you, almost everyone has had problems with the Sylvania bulbs. PIAA, although cost more, last much longer.......going on 7 years for me
Here is a set of H13 high/low beam LED headlights. They are nice but pricey.
https://www.lifetimeledlights.com/le..._led_headlight
Here is a link to an install video too
jimpennjr thanks for the links! Looks like these are real dual beam LEDs! Never heard about them before. They look a lot like the HID conversion kits - same structure, different bulb types. We used to sell HID conversion kits in the past, but many car owners experienced a lot of troubles with the wiring, ballasts, flickering and lasting. Hopefully these LEDs will turn out more reliable.
Applenut
105
02-20-2018 11:55 AM
