mood lights
Old Jan 25, 2009 | 04:43 PM
ChevyM84's Avatar
Question mood lights
i was wondering after looking at all the photos and seeing different color mood lights, where do you get these lights and what colors do they come in?
Old Jan 25, 2009 | 06:54 PM
catdaddy137's Avatar
ebay
and your local parts store , you may find some at walmart , as well as many other places. maybe our supporting vendors.
Old Jan 25, 2009 | 07:26 PM
ChevyM84's Avatar
cool i'll check it out, i wanna get a red one....thanks
Old Jan 25, 2009 | 07:46 PM
oneton's Avatar
You need a new LED if you what to change the light in the headliner!
Radio Shack
Old Jan 25, 2009 | 08:54 PM
tim_tenn's Avatar
I bought some LED modules from superbrightleds.com. Blue units with 3 LEDs in each. One above each front footwell, and one mounted in the lower console to light the small coin cubby and window switches. Easy to do and looks great.
Old Jan 26, 2009 | 02:54 PM
ChevyM84's Avatar
do you have to do any saudering?
Old Jan 26, 2009 | 03:48 PM
tim_tenn's Avatar
Nope. Used an add-a-circuit that I bought at Advance Auto. Spliced wires together using standard crimp-style barrel connectors. Wrapped all connections in electrical tape as a precaution. One ground connection made to the fuse block. Circuit #21 in the fuse block under the center console/waterfall is an open circuit that is ignition activated. When I turn on my key, the blue LEDs glow.
Old Jan 29, 2009 | 12:28 AM
Got my blue light, not from Kmart, but from Radio Shack. Easy to change out if you got a sunroof. Give me a holler, and I'll see if I can help.
Old Jan 29, 2009 | 01:15 AM
masterchief1112's Avatar
yeah if you have a sunroof just pry the back off above the sunroof. easiest way i found
Old Jan 29, 2009 | 01:23 AM
08BlkSS's Avatar
you should do a write up with pics
