Removing the double sided tape ......
Old Oct 1, 2013 | 02:19 PM
billk42's Avatar
HELP
I removed the hard plastic rock guards (at the rear door) to repaint them from all the road and rock damage. But now there is a continuous bead of double sided tape residue on the car (painted area). How do I remove it?
Old Oct 1, 2013 | 02:28 PM
Talia's Avatar
WD-40 should do the trick.
Old Oct 1, 2013 | 03:03 PM
badassbowtie's Avatar
WD40 is great! goo gone and rubbing alcohol will also do the trick without hurting the paint...use a microfiber cloth to get it off, and not something harsh, that can damage the paint...
Old Oct 1, 2013 | 06:59 PM
Some of those tapes leave a very thin strip of something like tape behind, so a razor blade could help.
Old Oct 2, 2013 | 03:42 PM
Doc brown's Avatar
Mineral spirits works great also.
Old Oct 3, 2013 | 12:58 PM
billk42's Avatar
Thank you
Thank you to everyone, used a combo of a couple of your suggestions, all the "goo" is gun the parts are sanded, primed, repainted and back on...woo hoo
Old Dec 9, 2013 | 10:39 AM
FatTireBiker's Avatar
Fishing line used like a saw works....for future reference
Old Dec 9, 2013 | 10:56 AM
cj krause's Avatar
eraser wheel you get at a English Colors paint store
they are amazing and easy to use and done nothing flat
Old Dec 9, 2013 | 03:52 PM
I use a heat gun along with WD-40. Works faster with heat, especially factory double sided tape.
Boydie
bluonyx
Aug 15, 2008 03:36 PM
teech
13
Oct 25, 2006 07:04 PM
Clarke33
Sep 1, 2006 02:23 PM
SindyDix
May 9, 2006 05:51 AM
12
May 1, 2006 07:02 AM
