Solstar rim info 4 install needed
So i have my spring and my 18 inch solstar rims should be here in the next day or so ,, a couple question do i need to use spacers and if so do i need to change the studs and the best size tire i shoulD order thanks in advance
what about the lugs what did you guy use
