Tinting tail lights
I have tinted tail lights, but I don't have a picture of them.
Here is the link of my tinted head lights, https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/my-smoke-headlight-17341/. I removes them due to safety concerns, but still keep the tail lights tint.
Pull em out, clean 'em up, line 'em up, and spray down the line, move at a steady speed and maintain your distance, make sure you're spraying them on an elevated surface that you can walk completely around so as to cover the entire lens. Coats will vary depending on how dark you wanna go, once done I would suggest a coat or two of clear as well
I did my markers and rear reflectors and can tell you this, they can get really dark, really fast!! I am afraid to try my tails. I would do my markers a little different....PM me before you do anything. Good luck!
We have done a few sets with nightshade for the GTO and some other friends cars. Time is a good thing to have. Make sure to let it dry between thin coats. Also worst case wet sand it back down to start over if you have to. We did that for the GTO's lights.
Also havn't looked at ours but make sure there are no raised letters / writting on the outside or else it will show through the tint funny. Use a low grit to sand it all off before you start. Also sand the whole lights to remove the clear before you start as well.
october5
19
Jun 6, 2012 01:06 AM
JRGHHRSS08
Aug 16, 2010 08:21 PM
