12V switched power?
Old Jul 22, 2010 | 09:50 AM
2003_2LT's Avatar
12V switched power?
I've done some reading and I think it's pretty neat how one box controls everything. However, it does make things a bit more difficult as far as wiring.
I am going to install a CB for my upcoming road trip. I would like to power it via switched power and have it turn off like the radio does when the door is opened.
What wire do I need to tap into to make this happen? I pulled out the radio the other day and the gauge on the wires are pretty minimal. I'd use whatever signal wire to power a relay and get the juice through a thicker wire elsewhere and avoid loading up the circuit.
Can anyone tell me what wire I need to find and tap into?
Help is much appreciated. Thank you.
Old Jul 22, 2010 | 10:11 AM
ssdivin's Avatar
There is 12v switched in the access door on the passenger side of shifter it's pink with white or just pink top row of wires
Old Jul 22, 2010 | 10:35 AM
solman98's Avatar
Switched power, turns off when you open the door.
teknolla
May 10, 2014 11:32 PM
B1GP1MP1N
7
Mar 1, 2011 05:59 PM
thedonn007
May 28, 2006 07:43 PM
jaydogg
Feb 24, 2006 12:48 PM
